Remove 93 Dash Pad
Remove the center defrost vent, there are 2 screws there.
the passenger side carpeted section is also part of the dash, make sure that is unbolted. I think there are a couple under the cluster surround, I know there is one by the driverside vent too.
Does the center defrost just "pop" out. I have had it about half removed, but I was afraid of breaking the round thing in the center. I have the cluster screws out and the driverside vent. I will look at the passenger carpet aread.
Thanks for the input, I have been sitting with a half assembled car all weekend.
Additonal question
I can currently reach the PKE and "buzzer" module. When moving the wiring for the modules, I can get the buzzer to start working. Does that give any insight what the problem might be? Obviously, I probably have loose connections, from anyone's experience, would you suspect that is an easy fix?
