Al Knoch Seat Covers for my '94
I'm looking into replacing the sport seat covers in my '94 ZR-1. Does anybody have any experience, good or bad with the Al Knoch covers that come on new foam? TIA.
Use the search function a lot of folks have mostly good and some bad opinions on Knoch covers. Again should find a lot.
Elite Torch Red Member
I got mine from Corvette America who makes them for Al Knoch.
The foam isn't as good as OEM, but you won't find the OEM anywhere that I know of.
Other than that it's pretty easy. The bottoms just pop out and the new one's pop in. As for the upper parts, it's a slight bit more difficult.
Remove the seats from the car, unzip the old covers slide them off, slide on the new, zip them down and then attempt to hook the bottom part together. It's a tight fit. Let the new covers sit out in the sun to soften up a bit and it will make life easier.
you will have to sort through these pics, but you can see what is involved in taking the seats out.
http://s68.photobucket.com/albums/i3...0Interior%201/
http://s68.photobucket.com/albums/i3...0Interior%202/
http://s68.photobucket.com/albums/i3...0Interior%203/
Most importantly, have patience and clean hands.
Al Knoch's regular price for sport seats on foam is $1000, usually on sale for $900.
I'm pretty sure Al Knoch makes his own seat covers. I would never consider Leather-Like (vinyl), when you go to sell it'll be the first complaint.. I've had some problems with Knoch, but nothing extrodinary.
Location: Assault is a behavior, not a device! Cypress TX
St. Jude Donor '11
I had Al put a set skins and new foam on my C5 during the last Corvette Expo in Houston. First class fit, quality and service.
I liked the whole experience so much I plan to have him put a new top on the vert at next year's event.
St. Jude Donor '08-'09
I've seen all his work in person at the NCRS shows down here in Orlando a few times. Top notch work!
All the Corvette seats from ALL the years you see on the web site, he travels with those and uses the ENTIRE set for display at the shows, They all look absolutely stunning in person. Fit, Finish, Feel, it all looks good.
I'd get a set, but I can't afford them
I put Al Knock in mt '82 and they look great. One seat had a little to thick of foam in the lumbar area. Shaved it down for a better fit on long drives. Mid America makes their own now and they even have two-tone.
do you have the link to the madvet sport seats? they said last year at carlisle that they were going to start two toning the sports seats but i can't find them. does al put the C4 logo on the back?
Replaced our seats with Al's and they are great and easy to do. On sale at most shows.
These are Sport Seats for the Collector Edition.... Took maybe an hour each to install, but I clean things up good and look at things as I do them, so normally doesn't take that long. Hardest part was unbolting the rear bolts on the passengers side. Once seats were out unzip, pull off and slipped new ones on and zipped up. Believe me if I can do it most people can
A couple years ago they were $900, on sale for $800 at Carlisle.
