LT1 2 Bolt Main?????
Old 05-25-2007, 10:27 PM
kylebuck89
kylebuck89's Avatar
St. Jude Donor '09
Default LT1 2 Bolt Main?????
I just took my motor out of my car and it is a 2 bolt main... i thought corvette lt1s had the 4 bolt main.
Old 05-25-2007, 11:36 PM
jakers
jakers's Avatar
St. Jude Donor '06
Default Could be original
I have heard on this forum that a few two bolt mains ended up in Corvettes off of the assembly line. According to some of the feedback I received, GM ran out of 4 bolt mains a few times on the assembly line as substituted 2 bolt mains to get cars finished and onto the showroon floors. BTW a 2 bolt main can be rebuilt and handle up to 400+ HP or you can beef it up and turn it into a four bolt main with some machine work.
Old 05-25-2007, 11:42 PM
kylebuck89
kylebuck89's Avatar
St. Jude Donor '09
Im just going to drop and LT4 into it..
its cheaper than rebuilding the one that spun a bearing... and what kinda hp would that motor put out with a two bolt main?
Old 05-26-2007, 12:15 AM
aboatguy
aboatguy's Avatar
Same as the engine would put out with 4 bolt main. For most applications having 4 bolt mains over 2 bolts is a moot point.
Most LT1s had 2 bolt mains (B-body and Fbody) Its relatively inexpensive to convert a 2 bolt LT1 into a splayed 4 bolt main engine and splayed 4 bolt mains are stronger than the factory style.
Where are you going to find a complete LT4 for less money than rebuilding your LT1 ?
Old 05-26-2007, 12:19 AM
kylebuck89
kylebuck89's Avatar
St. Jude Donor '09
My dad found a place in colorado that has a few left.. they are selling 4 around 4100 dollars or so... and it has the 3 year 100,000 warrent that if it breaks the DEALERSHIP has to work on it
Old 05-26-2007, 01:30 AM
DrEvil11417
DrEvil11417's Avatar
my '86 came with a 2 bolt main as well, stamp on water pump boss says it's the original motor too.. until then i could have sworn vettes came with 4 bolts
Old 05-26-2007, 08:05 AM
redvette6spd
redvette6spd's Avatar
You have a pm
Old 05-26-2007, 09:04 AM
aboatguy
aboatguy's Avatar
The L98s were 2-bolt mains, corvette LT1s are supposed to be 4 bolt .
Old 05-26-2007, 11:10 AM
mseven
mseven's Avatar
absolutely !!I like the bowtie block and the new lsx blocks w/6 bolt and raised cam tunnel cnc'd etc. is way cool!
To LT1 2 Bolt Main?????
Quick Reply: LT1 2 Bolt Main?????
