What is G92 - Performance Axle Ratio
Old 06-10-2007, 10:06 AM
tdellaringa
tdellaringa's Avatar
Default What is G92 - Performance Axle Ratio
What exactly is G92 - Performance Axle Ratio? How does it differ from the base if you didn't get that option?
Old 06-10-2007, 10:09 AM
Pete K
Pete K's Avatar
It is the performance gear ratio that gm assigned to a given model year, trans combination. In 87 on an automatic car, 2:59 was base, 3:07 was g92. 2:77 was base on verts.
Old 06-10-2007, 10:17 AM
c4cruiser
c4cruiser's Avatar
It simply identifies the car as having a performance ratio. There will be another RPO code starting with G that identifies the specific ratio.
G44 - Rear axle 3.07 ratio
G87 - Ring gear 8.50 inch
G92 - Rear axle performance ratio
GH0 - Rear axle 3.54 ratio
GM1 - Rear axle 2.59 ratio
GM3 - Rear axle 3.45 ratio
GT7 - Rear axle 3.33 ratio
GU2 - Rear axle 2.73 ratio
GW4 - Rear axle 3.31 ratio
The "performance" ratios were different between coupes and convertibles and auto trans and manuals and some years even got different ratios.
For example, my 92 'vert had the optional G92 "Performance Axle Ratio" and the specific GU2 2.73 ratio. The standard gear would hve been GM1 2.59 gears.
Old 06-10-2007, 10:20 AM
tdellaringa
Thanks, I see it G44.
To What is G92 - Performance Axle Ratio
Quick Reply: What is G92 - Performance Axle Ratio
