1992 C4 Base Suspension vs Z51
I have a 92 vette with the base suspension. Is it possible to switch the base suspension shocks with the the z51 suspension bilestien shocks? I want to get better handling, without lowering the car. Should I change the bushings as well?
Location: One day you're a Comet...the next day you're dust... Arkansas
Yes, you can install the Z51 shocks but there is much more to Z51 than shocks. The springs are different and the anti sway bars are different. Bushings aren't going to make much difference unless yours are bad.
z51 vs base shocks
I need new shocks and the difference between the base and z51 is not much. I don't want to spend the money to change out the springs.
Do you have the z51 or the base suspension?
Elite Torch Red Member
In all honesty, I don't think any of us would ever push the car to it's limit where you would notice any difference.
I've moved my 94 from base to Z51 in two stages: shocks only, then springs and sways.
By changing just the shocks, there was a dramatic improvement in handling. Less float and dive. It felt a lot better. However, after tracking the car, I quickly learned the base springs were just too soft to keep the car planted at speeds. And at autocross, there was too much body roll.
After changing the springs and sways, I have a whole new car. Handling is rock solid without being rough. I'd recommend a suspension replacement before any power mod. Even for the street, the upgrade is well worth the money.
1 Post
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Hi- I wanted to add that the difference between my Z-52 pkg on my '88 and the Z-51 pkg on my '96 is ASTOUNDING! And that's with many mods having been done to the Z-52 including lowering, poly bushings and Edlebrock shocks. The Z-51 stock still rides and handles night and day difference better!
How can i identify if my Vette got the special suspensio or just base ?
I have some yellow shocks but where are the options listed ?
on the VIN or the door ?
thanx
thanx
Nah it is just under the lid in your center console, like a little sticker, with a bunch of numbers printed on it. Mine actually has it under the lid on the rear storage bay. So you might look back there.
Z51 When you need to know about a members car you can look at their profile. Your profile is kinda skimpy, and some folks don't put anything. A more complete profile helps members answer your questions better.
Z51 as a specific option was dropped in 1990 and was replaced in 91 through 95 with the Z07 suspension package. The same features remained but the shocks that came on the Z07-equipped cars were a heavy duty version of the FX3 Selective Ride Control shocks (FX3 was part of Z07).
Z51 returned in 1996 and ws standard equipment on the Grand Sports.
'96 Z51 front and rear spring rates were different (and much less) than all prior Z51 or Z07 cars. In fact, '96 Z51 rates were very close to the base '95 suspension.
Sway bars also varied, with rear sway bars generally being 24 or 26 mm.
As someone mentioned above, on the street you will notice no difference between base and Z51 shocks. If your current shocks are shot, any new shock will feel better.
