Spark Plug Fouling Out...Need Help
Old 10-20-2007, 05:38 PM
The Batmobile
The Batmobile's Avatar
Default Spark Plug Fouling Out...Need Help
Hi, I have a spark plug that keeps fouling out. Ive been told that you can buy an extender to keep it from fouling out???? Is this true, and are there any other tricks to try and keep it from fouling out. Thanks guys, Zak.
Old 10-20-2007, 05:43 PM
arandy
Support Corvetteforum!
arandy's Avatar
St. Jude Donor '08
Check out the plug wire. If that's ok do a compression check.
Old 10-21-2007, 12:19 PM
xCCTer
CF JASOC Member
xCCTer's Avatar
Location: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Is the plug fouled with oil or fuel?
Old 10-21-2007, 02:53 PM
RRT vette
RRT vette's Avatar
Depending on what the plug looks like...you can ohm the injector on that cylinder and do a fuel pressure leak down test to make sure that injector is not causing the fouling. Also make sure that plug is getting spark when it should.
Old 10-21-2007, 04:44 PM
The Batmobile
Well, Im thinking about replacing the injectors anyway.
To Spark Plug Fouling Out...Need Help
Quick Reply: Spark Plug Fouling Out...Need Help
