Touch up Paint in a Spray Can?
I have a 1990 Polo Green Metalic (Paint Code 91) Vert. The underside of the Gas Door has quite a bit of rust under it and I was going to sand it down, treat it with Osfo and spray paint it green again. I have been looking for a spray can of touch up paint from the usual catalogs and all that is available is brush-on touch up paint. Does anyone know of a supplier that handles spray cans of factory correct touch up paint?
I've had good luck with Tower Paint (towerpaint.com). They will put anything you want in a spary can. Theye did a nice job matching my non-standard red. They also offer standard colors with the paint code. I found them in Hemming's Muscle Machines.
touchup paint
Try this link, have purchesed from them before, excellant results
http://www.paintscratch.com/
1990 polo Green
http://a85.ac-images.myspacecdn.com/...29dc1fda44.jpg
Vehicle: 1990 Chevrolet Corvette
Paint: Polo Green Metallic Clearcoat 91/WA9529
Qty Description Cost Total
1 12.5 oz. Basecoat Spray Can 24.95 24.95
1 12 oz. Clearcoat Spray Can 12.25 12.25
Total Shipping/Handling 7.95
Grand Total: $45.15
1990 polo Green
Grand Total: $45.15
I went by my local dealership and the paint in the spray can has been discontinued. They checked the other dealers and there is one dealer in the state of Florida that has one can. I called them and ordered it, but now they won't ship it because it is in an aerosol can......... Any ideas?
paint
i think dealer is bs you, i just ordered paint less than a month ago. i never heard of not shipping because of aresol. call them and tell them to ship it to you via ups. or go to paintscratch they are a good place to buy also and they will ship
If they ship ground ,they should be able to ship to you.
I get mine at the chevy dlr and they ship by boat.Great pant it has the clear coat and everything already in it.
As mentioned above, most automotive paint suppliers will put any color you want into an aerosol can.
If you can't find any local, and have to order they can ship it.
It just has to ship by ground. It can't ship by air.
Received 4,505 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Here are few places you might want to check out!
http://paintscratch.com/
http://drcolorchip.com/
http://www.automotivetouchup.com/
http://www.touchup123.com/
Last one is the place I used with excellent results.
http://www.brandsport.com/
When you order the paint, make sure they know that you have the 1990 color. Polo Green Metallic II from 1992 on is Code 45 (WA 9539) while 1990 is Code 91 (WA 9529) The later color is brighter with more of a gold metallic to it.
You can get other paint mfgr's codes here
Edit:
I did a search and found the old post for my color.
The DupliColor 5oz spray can should be DSGM432- Medium Green Metallic
http://forums.corvetteforum.com/show...ighlight=paint
1 Post
I had good luck with spray paint from NMB. They were able to match my Steel Blue Metallic. Go here:
http://www.nmbpaint.com/service.htm
