Rear wheel bearing clean up
Replacing all suspension bushings ect. Have rear wheel bearing out,needs cleaned up before install, will parts cleaner get into bearing lube, what precautions need to done, also other rubber parts and parts cleaner ? alot of parts need cleaned not replaced, just don"t need to be stupid now Thank you in advance. Craig 84 w/ 215000 mi
if i had an 84 w/215K miles, and everything apart, i throw in a new set of bearinig/hub assemblies. i know the old saying "if it ain't broke...", but why push your luck. go for new ones, and put another 215K on her.
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
