Lumbar Seat Pump/Motor
Anyone out there have a lumbar pump/motor they want to get rid of? I could use two of them for my 1990 if the price is right.
In the 80's/90's the company that manufactured most lumbar systems for american automotive seats was called Bytec. That may be spelled incorrectly, because I'm running off of memory. They supplied tier 2 Lear Corporation, which is who I think manufactured the Corvette seats as well. I believe that a lot of bladders/pumps were the same, but used in a number of different applications. You might be able to contact them if they're still around to possibly buy new, or find out the other applications that will interchange to save you money on used, so you're not limited to just Corvette parts. It's been a long time since I visited that plant, but it might have been in Southfield, Mi., or somewhere close to there. Good luck.
Replaced my pump diaphrams using a peice of bicycle tube, very easy and works great now. Saved $$$$. Also very easy to do, took about 2 hours to do both sides.
I fixed mine just like "lilredc4" did and it's as easy as they say. From what I've read the innertube fix may last longer than the latex glove material. Even if you have to buy a bike innertube they're only about $3.
