1985 Dash Pad removal
Old 04-01-2008, 09:46 AM
pote04
8th Gear
pote04's Avatar
Default 1985 Dash Pad removal
How do I remove the Dash pad in 1985 corvette?
Old 04-01-2008, 10:00 AM
QuikZilver
QuikZilver's Avatar
Remove 2 screws where the defroster vent is.
Remove 2 screws under the dash pad above the radio center panel.
Remove 2 screws under the dash pad above the instrument panel.
To gain access to the 2 screws above the instrument panel, you may need to remove the trim panel in front of the gauges, which also requires you to remove the radio center panel as well.
Once the 6 screws are removed, then you have to pull and the dash pad will come off.
Old 04-01-2008, 10:05 AM
rich653
rich653's Avatar
Once all the screws are out pull the dash towards you don't pry up on it or you'll break the clips, make sure all the clips slide into the retainers when your re-assembling or you'll have rattles a little grease on each clip helps.
Old 04-01-2008, 11:41 AM
Demonic85
Demonic85's Avatar
Remove center trim and the trim around the digi dash. Then remove the screws underneath that lip on the bottom of the dash pad. Dont forget to remove the last two bolts near the defrost vent on top by the windshield. Very easy to miss those.
To 1985 Dash Pad removal
Quick Reply: 1985 Dash Pad removal
