Pic of door panel fix
Old 03-15-2009, 08:50 AM
mrmtrtrnd
Support Corvetteforum!
mrmtrtrnd's Avatar
Good idea and very nice execution of that idea. Thanks for the pictures and all the information.
Old 03-15-2009, 09:08 AM
Mr Mojo
Elite Torch Red Member
Mr Mojo's Avatar
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Excellent! I'm going to do that with my '95
Old 03-15-2009, 01:13 PM
Nick DL
Nick DL's Avatar
Tagged for the future.Thanks for the tip and pictures.
Old 03-15-2009, 02:06 PM
bac22
bac22's Avatar
Cool...I just removed my door panel to work on replacing the window stop and noticed the exact same thing with the plastic on my panel. Now I know exactly how I'm going to fix it! Thanks for the tip!
Old 03-15-2009, 02:35 PM
CopperCorvette
CopperCorvette's Avatar
As like so many others I'm having the same problem on my 94. I'm thinking you should have made at least one more as a pattern and maybe even made a few bucks on the side.
Old 03-15-2009, 07:07 PM
Camaro350z28
Camaro350z28's Avatar
make a ton and sell them, and im on the list. bout to send the dimensions to my uncle with his water jet cutter.
Old 03-17-2009, 01:07 AM
CopperCorvette
Originally Posted by Camaro350z28
water jet cutter.
That's the way to do it. Clean and smooth edges. I'll take a set.
Old 03-17-2009, 07:30 AM
pivotpro
pivotpro's Avatar
Same Here. PM me if you are thinking about a mass production.
Old 04-10-2009, 12:26 AM
cam355aro
cam355aro's Avatar
The top plastic piece of my door panel (84) where the inner door seal is stapled into was broken when I replaced the inner door seal. I lost about 6 inches from the end. After stumbling upon this post, I plan on grabbing some flashing and super glue to fix it tomorrow. Thanks for the post, wish me luck!
Old 04-10-2009, 01:03 AM
ccrazor
ccrazor's Avatar
St. Jude Donor '08-'09
For future reference..
Old 04-10-2009, 08:39 AM
Goldcylon
Goldcylon's Avatar
Im in name a price.
Old 04-10-2009, 06:18 PM
LannyL81
LannyL81's Avatar
Doing this as well; my question is what was used to drill the holes? Tried to use a 3/8" drill, but of course the drill was too large to get close enough to the ribs for a straight shot.
What did you guys use?
Old 04-10-2009, 08:13 PM
  #33
jgclark
jgclark's Avatar
Default door fix
So my 94 drivers sides has the same problem. I have the brackets made up and I'm ready to go. But I'm waiting for a nice sunny day here in Michigan. My plan is to have the door panel sit outside to get nice and warm and pliable. Then I will use vise gripes to pinch the plastic web between the 2 brackets. Then drill, rivot and epoxy everything together.
Thank you so much for this idea. It truely is the only way to correct the C4 drooping door.
Old 04-13-2009, 10:48 AM
  #34
onedef92
onedef92's Avatar
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Please put me on your list, too. I need to repair the driver's side door panel on my '92 and was considering LouisvilleLT4's previous repair tip using nylon zip ties.
Old 04-14-2009, 09:31 AM
  #35
tomtom72
tomtom72's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'19, '21-'22-'23-'24
Default me too, me too...
I'm in if you are selling these!
Thanks!
Old 04-14-2009, 06:30 PM
  #36
rs/ss 67
rs/ss 67's Avatar
Do you have a link to this thread as I tried this one with no luck
Old 04-15-2009, 09:46 AM
  #37
onedef92
onedef92's Avatar
http://forums.corvetteforum.com/c4-g...wire-ties.html
Here's the link, but the results appear to be a mixed-bag, turkey shoot. Worked for some, but not all....
To Pic of door panel fix
Old 04-15-2009, 06:15 PM
  #38
rs/ss 67
rs/ss 67's Avatar
I have installed the metal brackets and now the zip ties with the same results--I now am going to pop rivet a peice of metal to the door and place a screw thru the panel into the plate. If in the future I hit the lottery I will spend the 500. for a new panel. Funny I just purchased a complete interior for my Camaro for 1200. that include 4 door panels head liner ,seat covers ,rugs and also a dash panel. Crazy what the vette parts cost.
Old 04-16-2009, 12:00 PM
  #39
onedef92
onedef92's Avatar
I don't know if I'd take a chance on one sight unseen, but you can buy a used door panel for $185 bones from Taber's Corvette Parts.
New ones run $429.00.
http://www.tabercorvetteparts.com/parts/dooracces.html
Old 04-16-2009, 12:03 PM
  #40
corvettedan22
corvettedan22's Avatar
Mine werent that bad I just 2 part epoxied them. If they ever get that bad this is what I will do thanks !
Quick Reply: Pic of door panel fix
