Toluene and Acetone
Toluene and Acetone
I mix 1 cup of Toluene to 5 gallons of gasoline and 1 cup of Acetone to 15 gallons of gasoline. The Toluene bumps up the octain a few points and the Acetone seems to clear up black soot in the exhaust, I'm not exactly sure what it does but it hasn't hurt vehicles I've used it in over the years.
My question is mostly for the injector tech's. Does the Toluene affect injector O-rings. I see alcohol as the worce thing you can add to gasolene. People "gasp" when I tell them I mix these things in my cars tank. To be honest, I've used Toluene in my motorcycles since the mid-seventies and in a turbocharged fuel injected bike without any noticable problems over a five year period.
1 Post
It's been reported the adding 1 to 3 onces of acetone to 10+ gallons of gas will increase the mpg noticably. Also cuts the soot/black smoke in diesels and car exhaust, however I can't verify this as I have never tried it.
Where do you buy toulene? Id like to test your theory.
Supporting Vendor
Toluene is fine to use in moderation.. it will not harm the injectors as far as I can tell. However, if you have a 94 or older multec.. DO NOT USE ACETONE. it will quickly deteriorate the seal between the injector orfice and the coil housing.. once the coil gets contamenated it will fail. Once one fails the others will soon follow. Pre 88 uses Bosch or Lucas injectors that acetone will not harm. Newer Bosch injectors are 100% complient to fuel additives, alcohol, and propane fuels because of their stainless steel construction. I cannot tell you how acetone affects other parts of the fuel system.
Thanks for the replies. I have probably been using too much Acetone. As mentioned, nothing bad happening so far. I do notice the exhaust stays clean. Fuels vary depending on regions. Whatever our "blend" contains, it's normal to see black soot in and around exhaust tips & surrounding bodywork. Doesn't matter what make of car or motorcycle.
Toluene is an old racers secret to bump up octane. It works. If you use too much, your exhaust will have a sweet smell to it. Around here it's tough to find because it can be misused to get high. I have to order it in five gallon containers at $85.00 from an automotive paint supply business. I am a regular customer so they know I'm not abusing it in other ways.
The highest octane around these parts is 91, and that could contain alcohol. A law was passed that pumps do not need to be labeled if the fuel contains alcohol. I haven't checked on this myself, but I was told race fuel is $10.00 a gallon this year. Is this true???
I have a turbocharged motorcycle that I modified the turbocharger myself. It can make 30psi of boost and stay together. It uses VP C16 race fuel.
If anyone decides to play with mixing. Please, do it outside and wear some kind of protective eyewear. I had no idea Toluene was used for anything other then paint thinner and as a model car glue carrier. Be careful out there!!!!
I have used acetone for years in cars. I primarily use it to clean out the top end and when I use it I only add a few ounces per tank once a month or so. At that rate it is so concentrated that it will not cause harm.
