Removing antenna C4
PO may not have hooked up the power signal lead from the new stereo system. You may end up replacing your antenna and it still not work. Can you ask the PO about this?
1 Post
Cruise-In X Veteran
St. Jude Donor '09
A quick search of the forum turns up alot of threads on antenna replacement. Usually it's the plastic ribbon attached to the mast that is either stripped/worn or broken. Stripped ones are a 15 minute deal to replace. Broken ones usually mean there are pieces left in the motor. Plan on couple hours.
http://forums.corvetteforum.com/show...t=antenna+mast
and
https://www.corvetteforum.com/techti...=185&TopicID=2
and
C4 Antenna Replacement
Good Job to JD5840! I would add that I have done it both ways. I think that removing the rear tail lights is easier, however you MUST remove the two bottom screws from the antenna FIRST, then remove the mast nut. Once you have done these two things, simply pull the antenna away from the mounting bracket.
In my case, I removed the mounting bracket to simplify removing the antenna out one of the tail-light holes so I could drill the rivets and remove the nylon antenna gear for replacement. I then put some gasket sealer around the edge, put screws in instead of rivets, put a large zip tie to hold it together well, and wrapped some electrical tape for good measure.
Hope this helps!
Hope this helps!
4th Gear
87 Antenna Won't Go Down
So I've tried getting to it through the taillights, but removing them is hellish. I've decided to check other websites and came across this: http://www.superchevy.com/how-to/vemp-0203-c4-corvette-antenna-repair/
Is this correct in saying that I should cut the wires? As of now, we could remove the antenna if it wasn't for the wires... So should I disconnect or cut them?
Antenna Falls Out
My '86 C4 antenna stays up. It falls over the fender (still attached) when the tuner is turned on, and reels back in to extended position when turned off. It's an aftermarket stereo that came with the car. Anybody familiar with this problem?
