89 air conditioner compressor
Hi, all. My AC went out and the compressor and clutch assembly must be replaced. I found one on GMparts direct but can't get confirmation that the complete clutch assembly is attached and complete. Has anyone ordered one and knows firsthand or does anyone know where I can get a compressor and complete clutch assembly that does not cost an arm and a leg? It is hot and your help will be appreciated!lol
IndianLan
IndianLan
May only end up costing a leg and the arm up to the elbow, but I hope it saves you a little time. Customer service is top shelf.
http://www.mamotorworks.com/corvette-3-136-3819.html
out of them
IndianLan
Hmmm...It appears finding one in-hand may be an issue regardless of vendor. The link below is special order as well, but at least it's another source for you to compare. Good luck!
http://www.corvettepartscatalog.com/...oducts_id=8364
Before you start, make sure it is just the clutch - can you still turn the outer hub by hand? Clutch assemblys should be plentiful - used from '88 to '96, though sometime around '93 the electrical connector may be a little different. NAPA and the discounters usually have a stocking number too - check their web sites. X-reference vehicle usuage at www.acdelco.com. To R & R, grab the outer hub with a strap wrench or some oil wrench pliers. Remove the 10 mm bolt. Gently tap or pry off the outer hub and hold your hand underneath it to catch any shims. Pulley and the coil underneath it are held on with snap rings. Installation is the reverse and aftermarket kits usually come with new snap rings and a shim kit (the OEM doesn't - you have to buy them separately). Make sure the snap rings are fully seated or it'll fall apart (and ruin it) the minute you start it. Shim the outer hub until there is an .020 inch air gap between it and the pulley (count on pulling it off once or twice). Get it too tight and the smell from the friction will overwhelm you. Get it too large and it'll engage with a loud clunk. Torque the retaining bolt to 10 ft/lbs - don't go ape on it or you'll crush the shim or damage the shaft seal.
SUNCR I have not tackled this yet too busy over the weekend with Weatherstrips - The noise seems to be there when the ac is on and off but it sounds like worn bearing - will the clutch resolve this issue?
I located what was supposed to be one at one of the corvette part places. When I showed it to my mechanic ( the drawing) He said it has a clutch but that is not what your condensor looks like. Yours is not flat.
Sind it was nonreturnable I told him to locate and install one. When his arrived it was flat. He had to return it and get the correct one.
Just wanted to mention it because I am sure glad I didn't spend $470.00 for a condensor and clutch that would not fit.
IndianLan
IndianLan
I don't know what you mean by Condensor - that's in front of the Radiator and has nothing to do with the clutch. The clutch assembly consists of the Face Plate or Outer Hub, the Pulley and then the Coil. If you mean the Face Plate of the replacement clutch looked different, that's just an aftermarket part and it doesn't effect performance. If you were concerned about it looking stock, than the OEM clutch assembly is the only way to achieve that. Aftermarket assemblys are usually $150; the OEM (acdelco) $250. The OEM doesn't include a shim kit either which is needed to set the air gap between the Face Plate and the Pulley. That'll set you back another $12 - which for 4 or 5 one quarter inch washers isn't much of a bargain either.
