Hood vents
#41
Bill; here's a video on how Callaway did it in 1988
I don't know what to do now. I own a body shop, so the installation of the louvers in the hood would not be that hard, just don't know if it will give me the air movement under the hood I'm looking for. There has to be a way of getting some cooler air up under the hood.
#43
This is my 91 Z-07 with the ones from Mold Kraft. Work well, they vent a boatload of heat. I have a 383 with Stainless Works headers and I noticed a difference right away.
http://www.greenwoodcorvettes.net/gc4/louvers.htm
$355
http://greenwoodvette.com/options.htm
$299 cheaper from Mold Kraft and same thing, I think he used to make them for Greenwood and he seems like a nice guy. Thats where I got mine.
#44
Not wanting to poke you with a stick, but why didn't your car come with them in the first place? I'm not a design engineer or anything like one, but it seems that there would have been wind tunnel test to prove out the final design.
#45
As I said in my earlier statement “depending upon your application, hood vents do work.” My Vette is no longer stock and the vents in my hood work two fold. The vent on the passenger side of the hood evacuates engine heat. The vent on the driver side allows the supercharger access to cooler air.
#46
#48
The ones on my car can be bought either way, show or go. I paid $100 more to get the rain diverter baffles for the inside of the hood. I know that at 120+ on the straightaway at the track they are pulling loads of heat off the engine and I run cooler water temps.
For an original equipment design with a properly sized cooling system you generally don't need them. But you will notice that most racers have extra venting on them somewhere up front.
#49
When GM wanted functional heat extractors, they put them on the side of the hood:
http://deliquescence.net/~tyler/prototype/active3.jpg
In fact, on many cars they have put them in that area, must be something to it...
#50
#51
What I meant was when GM puts heat extractors on real production cars, they put them on the sides. As to the active-suspension C4 in specific, one would think they put them where they did because it really worked. Those hydraulics apparently created a ton of heat. So if one was wondering about where a scoop might actually pull out hot air, there's one place where I'm reasonably sure it would.
#52
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
There's a lot to aerodynamics on high speed cars
You need to analyze the pressure zones, you could actually wind up with something that flows backwards from what you think it does.
There's a high pressure zone at the base of the windsheild, musclecars used it for "cowl induction"
#53
And at speed - "Zero" - front end float
#54
In traffic
If you're moving, then air is moving. Forget whether air is going in or out of louvers, cowls, & etc just for now. When you get stuck in traffic for a light, a wreck, or whatever (& are sitting still), heat will rise out of the louvers, through the back of the cowl (unless sealed up), or through whatever holes you have available for heat to rise out of. When you move again, the air will obviously cause different things to happen, but heat will rise out of louvers when you're stuck in traffic. I don't know how significant it is, but some is better than none, I guess.
#55
So are you saying that cutting out the cowl seal will help get hot air out from under the hood? But then I hear that the base of the windshield is a high pressure area, which is why cowl induction hoods work. So would cutting the cowl seal let hot air out or force cold air in? (I guess either one would be cooling the temp down.)
Also, why is the cowl seal there in the first place? Maybe to stop rain from being forced in? I'm confused!
Inquiring minds want to know...
BTW, I like the looks of the hood vents even if they are not letting hot air out.
Jim S.
Jim S.
#56
nobody knows for sure, at GM all such decisions are made by "committee", all those people are long gone.
most likely, to stop all that ugly engine noise...maybe to preclude hot engine compartment air from entering the cockpit air intakes at the base of the windshield and messin' the missus's 'do.
#57
Yeah the air intake is there for cabin air. I noticed when my car was stock that the fan took awhile to bring temps down. There isn't a lot of places for the air to go. I didn't want it all blowing on my trans making that hot either. So the seal is trimmed on mine. I've been thinking of adding vents for aero reasons. Yes that area is high pressure when moving. At idle is when I didn't really like the air flow. I'd like a no weight vented hood one of these days!
#58
these are the ones I got from
MOLD KRAFT MANUFACTURING, INC.
1683 Beardall Avenue #101
Sanford, FL 32771
Phone : 407-321-1016 Fax :407-324-3646
E-Mail Us at info@greenwoodvette.com
edit......cheeze, I just noticed that I previously responded to this thread over a year or so ago
#59
Cowl
Jim S.
Jim S.
I hope this clears things up a bit. A street car, & a 100% all-out racecar are totally different beasts with different setups.
#60
Examples
Check out this Corvette that has a sealed cowl & a hole in the front of the hood to get radiator heat out!
Here's the link:
http://s64.photobucket.com/albums/h167/Tazio_Nuvolari/
Here's the link:
