C4 Weights and Info
Old 01-09-2014, 06:30 PM
  #81
locobob
locobob's Avatar
Base seat (94-96) with power track = about 35lbs
Seat is roughly 20lbs
Power track roughly 15lbs
Old 06-19-2014, 06:25 AM
  #82
Annoyed
Annoyed's Avatar
C4 Corvette breadbox with the 4 small alloy brackets on it = a massive 1.986 kilos aka 4.3784 pounds
Old 08-14-2014, 01:22 AM
  #83
Slow86vette
Slow86vette's Avatar
It looks like the stock power seats in our cars are pretty light. I figured they would've been more than 40 lbs with the tracks. Also to add to this, my (at the time stock) 86 premium z51 coupe weighed 3127 with a full tank, a toolbox in the hatch, and 4 or 5 college books in the passenger seat without me in the car. This car also had a d44. I would assume the books were 20ish lbs, the toolbox is about 45 (small box with simple tools). The early cars are good candidates for turning into racecars since they are already so light 😁
Old 09-30-2014, 10:19 PM
  #84
mike thrasher
2nd Gear
mike thrasher's Avatar
Default i'm a new member
I have a 1984 white, targa top vette! cross fire with manual four over three tranny! red interior, need much work! especially carpet! has cruise, tilt, air, digital dash! rpm indicator works rarely! air blows mild air! tail lights don't work all other rear lighting applications do! ele windows recently stopped working! I replaced all fuses with correct amp fuses but this didn't help! bought a switch that goes under the break pedal but don't know how to install! someone before me must have redone the engine because it screams! I had a 375hp 69 ss Camaro but my vette seems at least as responsive! I just discovered this application on my computer but it has already helped me! mike
Old 10-04-2014, 11:55 AM
  #85
cudamax
cudamax's Avatar
This is a Great Thread. I looked everywhere. Does anyone have any weights on all the glass on these cars? Rear window/Windshields & door glass?
Old 11-09-2014, 05:50 PM
  #86
kimmer
kimmer's Avatar
C4 of the Year Finalist
Old 11-22-2014, 11:54 PM
  #87
l98tpi
Max G’s
Support Corvetteforum!
l98tpi's Avatar
Rear hatch glass @30lbs. You can substitute with polycarbonate for around 12lbs.
Old 11-22-2014, 11:58 PM
  #88
l98tpi
Max G’s
l98tpi's Avatar
Just weighed 91 Sport Seat tonight and came to 19lbs 4oz. This is for the seat only. Does not include the track. But show how light these components in these cars can be without the extras. There are carbon seats out there that weigh as much or more.
mjlorenson (12-09-2022)
Old 05-04-2015, 02:03 PM
  #89
oldpro
oldpro's Avatar
95 zr1 weight is over 3500 lbs not 3200
Old 08-13-2015, 10:41 PM
  #90
Aardwolf
Aardwolf's Avatar
1988 Horn each (there are 2) 1 lbs.
1988 electric door lock motor each (there are 2) 11 oz.
I'm down to 2990 race weight (NASA track scale) with me (200 lbs) and 12 gallons of fuel (72 lbs). Making the car pretty light dry at 2718. 2600's are not far away! I still have stock glass, iron block, and stock column. Next will be a race steering column and wheel.
Old 08-14-2015, 09:46 PM
  #91
l98tpi
Max G’s
l98tpi's Avatar
Where are you getting a race steering column? How much weight saved there? Can the race steering column accommodate the turn signal and wiper stalk?
Old 08-15-2015, 12:07 PM
  #92
Aardwolf
Aardwolf's Avatar
I haven't decided what parts numbers yet. I'm using a parts diagram from Woodward for what to measure. I'm also looking at a few Allstar parts.
http://www.woodwardsteering.com/PDF/...Releases-1.pdf
http://www.summitracing.com/parts/aa...2170/overview/
I do not need the stalk (removed wipers etc) and may use buttons for the signals since I do still street drive it.
The column is really heavy I didn't remove it for a weight yet. When I gutted in the interior I had to wire it to the roof. I would guess it's 25 lbs.
Old 08-17-2015, 09:42 PM
  #93
l98tpi
Max G’s
l98tpi's Avatar
Thanks for the info, please keep us posted on progress and how much the stock column weighs
Old 08-18-2015, 10:11 PM
  #94
BOOT77
BOOT77's Avatar
Figured I'd save someone the trouble, I did my homework but the weights I read were much higher. 86 energy absorber just over 6lbs(I read 10 to 15), impact bar w/o lights, but with the top bar/bracket still riveted on just under 12lbs(I read 14 to 35). I was trying to trim a few pounds off the nose like I did on my 77(40lbs w/o much effort). I may trim 3-5lbs and it's not worth the effort and fun to re-align it all.
Old 05-01-2016, 08:24 PM
  #95
pologreen1
pologreen1's Avatar
Anyone know the weight on a c4 convertible complete frame with canvas on it?
I want to remove mine.
Old 10-29-2018, 11:11 AM
  #96
Nokones
Nokones's Avatar
American Custom Ind ACI race hood 45 lbs $860
Black dog speed shop carbon fiber hood 26 lbs Clear Finish $5000 Paintable opaque finish $3750
Toledo Pro fiber glass 33 lbs $800
Are the Carbon Fiber with frame Roof Panels still available?
Old 01-01-2019, 05:36 PM
  #97
tashea
4th Gear
tashea's Avatar
did you ever get a reply on the weight of the complete convertible top assembly for your c4 ?
To C4 Weights and Info
Old 08-22-2019, 06:46 AM
  #98
Mr. Magoo
Mr. Magoo's Avatar
Location: Damn taxes! Pimpin' Ain't Easy in Massachusetts
2018 C4 of Year Finalist
St. Jude Donor '03-'04-'08-'09
Wow, the ‘86 Coupe was in a diet.
Old 07-02-2020, 11:42 PM
  #99
Krusty84
Krusty84's Avatar
Rear honeycomb under bumper absorber - 6lbs 6oz.
Seats with manual tracks - 31lbs each
Manual seat tracks w/ bolts - 6lbs each
Seatbelt and bolts - 3lbs 14oz each side
Cargo side carpet (without foam padding)- 3lbs 10oz each side
Behind seat carpet (with padding) - 5lbs 6oz
Rear speaker foam insulator tubs - 2lbs 8oz each
Front upper wheel well with rubber seal - 3lbs 1oz each side
Cargo shade, cargo shade tracks, rear trim, rear speaker mounts, forward hatch strut mounts - 10lbs 14oz
Hatch strut and glass mount - 1lb 8 oz each side
Old 08-10-2020, 02:45 AM
  #100
Casethecorvetteman
Casethecorvetteman's Avatar
Default Suspension specs per year
| Spring Rate | Wheel Rate | Antiroll Bar | Wheels | Tires | Shocks | Ft.Lower
| in N/mm | in N/mm | Dia. in mm | in X in X mm offset | | | Bushings
| Front Rear | Front Rear | Front Rear | Front Rear | Front Rear | |
1984
FE1 63.5 72.0 21.5 28.6 24 S 20 S 15x7x17 15x7x17 215/65R15 215/65R15 1 N
16x8.5x32 16x8.5x32 255/50VR16 255/50VR16 1 N
Z51 102.0 87.5 28.6 37.5 25 S 23 S 16x8.5x32 16x9.5x38 255/50VR16 255/50VR16 1/4 HD
1985
FE1 54.0 39.9 17.5 24.1 24 S 20 S 16x8.5x32 16x8.5x32 255/50VR16 255/50VR16 1/3 N
Z51 63.5 57.2 26.0 30.6 30 S 24 S 16x9.5x38 16x9.5x38 255/50VR16 255/50VR16 1/4 HD
1986
CPE FE1 51.8 39.9 18.0 24.1 26 T 20 S 16x8.5x32 16x8.5x32 255/50VR16 255/50VR16 1/3 N
Z51 66.5 57.2 26.0 30.6 30 S 22 S 16x9.5x38 16x9.5x38 255/50VR16 255/50VR16 4 HD
CNV FE1 54.4 39.9 19.0 24.1 26 T 19 S 16x8.5x32 16x8.5x32 255/50VR16 255/50VR16 2/3 N
1987
Z52 51.8 39.9 18.0 24.1 30 S 20 S 16x9.5x38 16x9.5x38 255/50VR16 255/50VR16 3 N
Z52 54.4 39.9 19.0 24.1 26 T 20 S 16x9.5x38 16x9.5x38 255/50VR16 255/50VR16 3 N
1988
CPE FE1 93.1 39.9 26.7 25.7 26 T 22 S 16x8.5x50 16x8.5x50 255/50ZR16 255/50ZR16 1/3 N
Z52 93.1 39.9 26.7 25.7 26 T 22 S 17x9.5x56 17x9.5x56 275/40ZR17 275/40ZR17 3 N
Z51 115.5 57.2 30.8 33.5 30 S 24 S 17x9.5x56 17x9.5x56 275/40ZR17 275/40ZR17 4 HD
CNV FE1 93.1 39.9 26.7 25.7 26 T 22 S 16x8.5x50 16x8.5x50 255/50ZR16 255/50ZR16 2 N
1989
CPE FE1 93.1 39.9 26.7 25.7 26 T 22 S 17x9.5x56 17x9.5x56 275/40ZR17 275/40ZR17 3 N
FX3 93.1 39.9 26.7 25.7 26 T 22 S 17x9.5x56 17x9.5x56 275/40ZR17 275/40ZR17 5 N
Chal. 115.5 57.2 30.8 33.5 30 S 24 S 17x9.5x56 17x9.5x56 275/40ZR17 275/40ZR17 5 HD
CNV FE1 93.1 39.9 26.7 25.7 26 T 22 S 17x9.5x56 17x9.5x56 275/40ZR17 275/40ZR17 3 N
1990
CPE FE1 93.1 39.9 26.7 25.7 26 T 24 S 17x9.5x56 17x9.5x56 275/40ZR17 275/40ZR17 3 N
FX3 93.1 39.9 26.7 25.7 26 T 24 S 17x9.5x56 17x9.5x56 275/40ZR17 275/40ZR17 5 N
ZR1 96.2 39.9 27.1 25.7 26 T 26 S 17x9.5x56 17x11x36 275/40ZR17 315/35ZR17 5 N
Z51 115.5 57.2 30.8 33.5 30 S 26 S 17x9.5x56 17x9.5x56 275/40ZR17 275/40ZR17 4 HD
R9G 115.5 57.2 30.8 33.5 30 S 26 S 17x9.5x56 17x9.5x56 275/40ZR17 275/40ZR17 5 HD
CNV FE1 93.1 39.9 26.7 25.7 26 T 24 S 17x9.5x56 17x9.5x56 275/40ZR17 275/40ZR17 3 N
1991
Z07 115.5 57.2 30.8 33.5 30 S 26 S 17x9.5x56 17x9.5x56 275/40ZR17 275/40ZR17 5 HD
1992
CPE FE1 73.2 39.9 23.9 25.7 26 T 22 S 17x9.5x56 17x9.5x56 275/40ZR17 275/40ZR17 3 N
FX3 73.2 39.9 23.9 25.7 26 T 22 S 17x9.5x56 17x9.5x56 275/40ZR17 275/40ZR17 5 N
ZR1 75.4 33.0 25.4 22.6 26 T 26 S 17x9.5x56 17x11x36 275/40ZR17 315/35ZR17 5 N
Z07 90.1 57.2 29.4 33.5 30 S 24 S 17x9.5x56 17x9.5x56 275/40ZR17 275/40ZR17 5 HD
CNV FE1 73.2 39.9 23.9 25.7 26 T 22 S 17x9.5x56 17x9.5x56 275/40ZR17 275/40ZR17 3 N
1993
CPE FE1 73.2 39.9 23.9 25.7 26 T 24 S 17x8.5x56 17x9.5x56 255/45ZR17 285/40ZR17 3 N
FX3 73.2 39.9 23.9 25.7 26 T 24 S 17x8.5x56 17x9.5x56 255/45ZR17 285/40ZR17 5 N
CNV FE1 73.2 39.9 23.9 25.7 26 T 24 S 17x8.5x56 17x9.5x56 255/45ZR17 285/40ZR17 3 N
1994
CPE FE1 73.2 39.9 23.9 25.7 26 T 24 S 17x8.5x56 17x9.5x56 255/45ZR17E 285/40ZR17E 3 N
FX3 60.0 26.0 19.0 18.0 26 T 24 S 17x8.5x56 17x9.5x56 255/45ZR17E 285/40ZR17E 5 N
CNV FE1 73.2 39.9 23.9 25.7 26 T 24 S 17x8.5x56 17x9.5x56 255/45ZR17E 285/40ZR17E 3 N
1995
CPE FE1a 73.2 39.9 23.9 25.7 26 T 24 S 17x8.5x56 17x9.5x56 255/45ZR17E 285/40ZR17E 3 N
FE1b 60.0 26.0 19.0 18.0 26 T 24 S 17x8.5x56 17x9.5x56 255/45ZR17E 285/40ZR17E 3 N
CNV FE1a 73.2 39.9 23.9 25.7 26 T 24 S 17x8.5x56 17x9.5x56 255/45ZR17E 285/40ZR17E 6 N
FE1b 60.0 26.0 19.0 18.0 26 T 24 S 17x8.5x56 17x9.5x56 255/45ZR17E 285/40ZR17E 6 N
1996
CPE FE1 60.0 26..0 19.0 18.0 26 T 24 S 17x8.5x56 17x9.5x56 255/45ZR17E 285/40ZR17E 3 N
FE1GS 60.0 26..0 19.0 18.0 26 T 26 S 17x9.5x56 17x11x50 275/40ZR17 315/35ZR17 3 N
F45 60.0 26.0 19.0 18.0 26 T 24 S 17x8.5x56 17x9.5x56 255/45ZR17E 285/40ZR17E 7 N
F45GS 60.0 26.0 19.0 18.0 26 T 26 S 17x9.5x56 17x11x50 275/40ZR17 315/35ZR17 7 N
Z51 73.2 33.0 23.9 25.7 26 T 24 S 17x9.5x56 17x9.5x56 275/40ZR17 275/40ZR17 4 HD
Z51GS 73.2 33.0 23.9 25.7 26 T 26 S 17x9.5x56 17x11x50 275/40ZR17 315/35ZR17 4 HD
CNV FE1 73.2 39.9 23.9 25.7 24 T 24 S 17x8.5x56 17x9.5x56 255/45ZR17E 285/40ZR17E 6 N
F45 73.2 39.9 23.9 25.7 24 T 24 S 17x8.5x56 17x9.5x56 255/45ZR17E 285/40ZR17E 8 N
CODES
S-Solid antiroll bar
T-Tubular antiroll bar
1-Delco shock
2-Delco shock, convertible specific
3-Delco/Bilstein gas shock
4-Delco/Bilstein gas shock, Z51 specfic
5-Ride-adaptive Delco/Bilstein gas shock
6-Delco/Bilstein gas shock, convertible specific
7-Delphi bi-state ride adaptive gas shock
8-Delphi bi-state ride adaptive gas shock, convertible specific
N-Normal, front, lower control arm bushings (ft. 11k n/mm, rr 2.3k n/mm)
HD-Heavy-duty, front, lower control arm bushings (ft 13.5k n/mm, rr 3.5k n/mm)
E-EMT tire available,
a-early
b-late
GS-Grand Sport
Quick Reply: C4 Weights and Info
