What is the difference between the LT1 and LT4?
What is the main difference between the LT1 and LT4 and is it possible to convert you LT1 into an LT4? If so what is the process involved and how much does this conversion cost? Thanks :yesnod:
Re: What is the difference between the LT1 and LT4? (Double Black Vette)
Not sure how much it will cost but I think others have discovered its not worth the money to upgrade just to an LT4. If you are gonna spend that type of money go for as much HP & torque as you can. Remember the LT4 is listed as only 30 hp more than a LT1 but popular opinion says that the LT4 is approx. 10% underrated HP wise.
As far as differences between the LT4 and LT1 models, In 96 it meant automatic transmission vs Manual transmission & I believe the brakes were upgraded but I am not positive on that one. Some one else will probably chime in on that one if I am wrong.
The LT1 is a strong engine and will perform like an LT4 in the proper hands. :smash: But in those same hands it will out perform an LT1. Don't underrate an LT1s performance level :yesnod: It has surprised a many a LS1. :)
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Re: What is the difference between the LT1 and LT4? (CowboyNVette)
What he said. That LT-1's one helluva powerplant. It's seamless blend of torque and horsepower makes for one incredible rush hour blast-off, I can tell you that.
And it's so civilized around town, your grandma could tool around with it all day and never miss a beat. Easily one of the finest engines the General's ever let out of his arsenal. :cool:
The main differences?? Hmm, well the heads are one item with bigger but lighter wieght sodium filled valves, stiffer springs, 1.6 roller rockers, better port designs. The crank has got more machining to it for better high performance use (fillet journals, nitrided I think). The intake is different (other then the red paint) LT1 and LT4 heads and intakes are not interchangeable without machining. LT4 has no EGR system, different knock module because of valve train noise, better timing chain setup.
All 95 and 96 vettes have the 13" brake system regardless of engine by the way.
I remember a website that discribes the differences between the two, I just don't remember where.
Cost to upgrade?? $ :eek: $$$ :eek: $$$
Here's a good web site with the differences between an LT1 and LT4:
http://home.tir.com/~steveher/lt4.html
Bone stock LT4's generally output from 295-305 RWHP. That's 347 - 358 HP at the crank. There is NO question the LT4 was underrated.
The LT1 is a fine motor, though, and can be easily built up to exceed the LT4's output. LT4 heads are a huge improvement but for the cost, if I were you I'd massage the LT1 heads, port match the intake, install cam and headers and go out and have some fun!
1 Post
Re: What is the difference between the LT1 and LT4? (Z06VERT)
