1989 Z-51 or 1990 Z-51
6th Gear
I am looking at a stock C4 for SCCA autocrossing this year.
Which car in stock trim would be faster and handle better? I know the 1990 is rated with a little more HP and the 1989 had the 3.54 gear. It is also my understanding the 1990 weighs a little more.
So which would it be a 1989 Z-51 with 3.54 rear gear or a 1990 Z-51?
Thanks,
Dave :chevy
Thanks,
Dave :chevy
6th Gear
Re: 1989 Z-51 or 1990 Z-51 (scorp508)
scorp508,
The 89 Cars built in the first couple of months had the 3.54 gear. In SCCA Stock class rules, cars with Z-51 option are allowed to update the 3.33 gear to a 3.54 due to it's avialability.
Dave :chevy
Dave :chevy
Re: 1989 Z-51 or 1990 Z-51 (davege)
Early 89s did have 3.54s.
I'm not at home, so I don't have my suspension spreadsheet in front of me, but 89 Z51 cars came with 30 mm bars up front, and 24 mm bars in the rear. I know the 91 Z07 came with a 26 mm rear, but I'm not for certain if the 90 Z51 came with it or not. Spring rates however, are the same.
As far as weight is concerned, I'm sure that it is a minimal difference. The only difference is the interior.
90 Corvettes had 10.25:1 compression and used speed density engine control management, where the 89 had 9.5:1, and used mass air flow control.
All of these differences are so minute, that it won't make a difference one way or another in my view. Differences between the cars on a track would probably come down to drivers.
Re: 1989 Z-51 or 1990 Z-51 (White Lightning 89)
84-89 have a stiffer structure. (The interior bracing is better, because of where the front speakers are in the 90up)
[Modified by dgoodhue, 1:19 PM 2/1/2002]
I have an '89 Z51 (late production thus the 3.33 ratio) and I autocross it and I love it. Can't say how it compares to a '90 as I've not driven one.
scorp508,
Location: And on the fifth day, subpoenas were served to Obama senior staff
1 Post
Re: 3.33
I like the 3.33; 4th is good for a little over 120 which is just about right for the north course at Pocono and an L98. I hate to have to grab 5th as I can't heel toe worth a darn. :rolleyes:
Only issues I see; (without looking at the spring chart also) is airbag on 90 and no bag on 89. I don't know if the sport seats are the same, but the 89 sport seats kick butt. Also 90 has two fans on the engine side of the radiator and the different slant on the radiator, while 89 has a single large fan, the straight up and down radiator and the aux fan used as a pusher. If I had a car that might be checked I would want the 89 for the MAF. In 90 you might have to tweak programming a little more for some certain, um hidden changes like passing steel ***** through the runners or maybe a little challange cheater cam or something like that.
Location: ...tearing up the highways, one state at a time™®©
Received 2,102 Likes
Thanks,
Dave :chevy
Thanks,
Dave :chevy
Re: 1989 Z-51 or 1990 Z-51 (*89x2*)
Someone said the compression ratio was higher however, that didn't happen until the reverse cooling LT1's in 92. IMO the 89 is a better car for all around including racing but then again, I may be partial :D
It is true. My '87 is a 9.5:1 ratio, and it was upped to 10.20:1 (I think) later on.
FWIW, the LT1's touted higher compression achieved through reverse cooling... I got it on my L98 by shaving the heads and inst thinner gaskets...then there are the pistons... :jester
:confused: When? Where?I have never seen an L98 advertised w/ more than 9.5:1c/r :confused:.
1 Post
Black book shows 5hp improvement in 90 due to camshaft and compression ratio changes. Does not mention how much change in CR.
I honestly can't remember what year was the switchover.
C4's did have less c/r when equipped w/ Iron Heads...
Received 1,400 Likes
Right, but that isn't the swap I meant. The iron heads had a 74cc combustion chamber right? The L86-91 head had 58cc chambers. As stated above I guess it was 1990 that it was done along with the other things like the slanted radiator.
...Wouldn't take a 90 unless free, then only to re-sell... :cheers:
6th Gear
89x2,
It was my understanding the hp improvment on the 90 engine was due to the lighter hyperutectic (sp?) pistons and possibly lighter rods. I need to check my parts books on this. Some people think the removal of the MAF going to speed density also contributed.
When you look at the Cam specs of a 90 compared to a 89 the 90 had a closer lobe center, less lift and less duration on both the intake and exhaust.
Dave :chevy
Dave :chevy
