What's the Best Way to Wash a C4 Engine Bay?
I've been told it's not a good idea to power wash or hose down the engine bay for fear of getting the optispark wet.
My engine bay really could use a good cleaning. Got any tips?
1 Post
It really depends on the year of your car. If it has an opti, I wouldn't hose it down. I'd simply Simple Green it until it was all nice and clean. A non-opti, you can use a hose. An opti that gets wet is VERY likely to crap out on you and that's an expensive fix.
Dangerous waters...
I live on a dirt road, so dirt is a never ending battle. Having had my share of issues with washing the engine bays of not just Corvettes, I avoid pressure washing pretty much all together, except on areas where I know electronics will not get wet; e.g. suspension parts, cross member areas, and the like. Like the man said, "Simple Green" will do the heavy lifting, and if you want, you can remove the nozzle from the garden hose and gently rinse off the areas that are electronics free.
For the underside of the hood, I cover the bay with a tarp and after a pre-soak with SG, the garden hose/nozzle will work - or use your pressure washer (everyone has one of those, right??)
Beyond that, SG and rags, and more rags and once "clean", those silicone sprays will give it a clean, shiny look. Get carried away with water (pressure washing especially) and sooner or later it'll bite ya. If you have the Opti-spark, you have a terrific ignition system...until it gets wet. So, definitely avoid any water around the front of the LT1/4 engines.
Oh! Be sure to use plenty of elbow grease...and some more rags!
P.
P.
Where is the Opti located? Sorry for the question but I'm new to Vettes. I have a 96.
What I've done with my other cars is when I'm done washing the car, any soap left in the bucket gets thrown on the engine. I then hose it down. Never had a problem, but I've read posts here that this can be a problem with the Vette. What should be covered if you wanted to hose it down?
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
It's in the pic here. Directly under the water pump (great location as electricity and water don't mix).
Your '96 has the improved, vented Opti with a vacuum line designed to remove moisture, but you're playing on borrowed time if you continue to spray your unit with water during engine cleanings.
I'd stick with Simple Green and a whole bunch of shop towels, personally. But you should definitely wrap the coil, ICM and Opti in plastic to prevent them from getting wet.
Use the Simple Green that is made for automotive applications. It's supposed to be easier on the cast aluminum parts.
It does a good job but it actually has a blue tint. Shouldn't it be called Simple....Blue?
