will original 1994 rims fit with a j55 Upgrade
Old 06-12-2009, 02:52 PM
Rocket22
Rocket22's Avatar
Default will original 1994 rims fit with a j55 Upgrade
I have the 12" rotor setup, do I need to switch rims with the j55 upgrade?
Old 06-12-2009, 02:58 PM
Sweet 90
Sweet 90's Avatar
I don't think so. My '90 has the bigger brakes and I'm sure the stock rims were the same with or without the upgrade.
Jim
MarkBychowski
MarkBychowski's Avatar
Yes. J55's came standard in 95-96 and used the same front wheels.
Old 06-12-2009, 03:03 PM
jrzvette
jrzvette's Avatar
Location: The reason time exists is so everything doesn't happen at once
You don't need to change rims. The C4 used the same wheels for both the standard and J55 brakes. If you upgrade to C5 brakes you will need either A molds or C5 wheels.
Old 06-12-2009, 04:08 PM
pologreen1
pologreen1's Avatar
Old 06-12-2009, 04:15 PM
Eakster
Eakster's Avatar
Originally Posted by pologreen1
+1
You're probably thinking of the C5 brake upgrade
Old 06-12-2009, 11:59 PM
MarkBychowski
Sorry, when I said "yes" I was answering the title question: "will original 1994 rims fit with a j55 Upgrade?" -- yes they will
To will original 1994 rims fit with a j55 Upgrade
Quick Reply: will original 1994 rims fit with a j55 Upgrade
