86 Horn "barely" working? - CorvetteForum - Chevrolet Corvette Forum Discussion
C4 General Discussion
General C4 Corvette Discussion not covered in Tech
Old 07-01-2009, 03:36 PM   #1
C4Finally
Junior Member
C4Finally's Avatar
Default 86 Horn "barely" working?
Hey all...
Just realized my 86 vert's horn is barely working. When I push the horn button, the horn goes off, but only with a barely audible sound; not near enough, I am afraid. Do you think it is the horn itself, or something in the circuit between the button and the horn? I have never had this happen to me on a car before...
Anybody else had this problem?
C4Finally is offline   Reply With Quote
Old 07-01-2009, 03:48 PM   #2
MK 82
CF Senior Member
MK 82's Avatar
The stock horns are notoriously crappy. Get yourself a good aftermarket set.
MK 82 is offline   Reply With Quote
Old 07-01-2009, 03:53 PM   #3
takovr
CF Senior Member
takovr's Avatar
Default Same problem
I had the same problem on my 86 corvette, horns started to loose sound, I replaced both of them and all is good now.
takovr is offline   Reply With Quote
Old 07-01-2009, 04:09 PM   #4
floridamale
CF Senior Member
floridamale's Avatar
There is a adjuster on them sometimes it works sometmes it dosen't
floridamale is offline   Reply With Quote
Old 07-01-2009, 04:19 PM   #5
jimg's'93
CF Senior Member
jimg's'93's Avatar
You can try and clean the contacts at the steering wheel, but I agree w/ the others; sounds like the horns themselves are shot.
jimg's'93 is offline   Reply With Quote
Old 07-01-2009, 04:35 PM   #6
Shimy86
CF Senior Member
Shimy86's Avatar
any GM horn from a junkyard will work also. To the OP....nice beaver
Shimy86 is offline   Reply With Quote
Old 07-01-2009, 04:55 PM   #7
pologreen1
CF Senior Member
pologreen1's Avatar
common on that style steering wheel
pologreen1 is offline   Reply With Quote
Old 07-01-2009, 05:06 PM   #8
glava2876
CF Senior Member
glava2876's Avatar
Quote:
Originally Posted by C4Finally View Post
Hey all...
I had this problem on my 84 and cleaned them up and everything and they only got slightly better. I bought the NAPA replacements, at $15.00 ea. which are not the same as the originals -they have a universal mount etc. with a bracket that bolts to the horn and then to the chassis. Sort of a flimsy crapy bracket that you have to bent to orient them in the factory location.
I actually cut the factory bracket at the horn where it is welded and rounded of the corners, hit them with chassis black and attached the horn to the bracket through an existing hole in the factory bracket and then the horns bolted right up to the chassis using the factory bolts. Not sure is the 86 is the same.
Glen
glava2876 is offline   Reply With Quote
Old 07-01-2009, 10:43 PM   #9
RedVette84
CF Senior Member
RedVette84's Avatar
I just had to replace my horns. One was dead and the other worked sometimes. Can't get new originals just generics unless you find used ones. Took a members advice and put WoLo's from Pep Boys on. Seem to work well enough.
RedVette84 is offline   Reply With Quote
Old 07-01-2009, 11:07 PM   #10
ch@0s
CF Senior Member
ch@0s's Avatar
All horns are crappy when they are 20 years old.
Replace them and all will be well.
ch@0s is offline   Reply With Quote
Old 07-01-2009, 11:20 PM   #11
ZRWON
CF Senior Member
ZRWON's Avatar
Quote:
Where on the horn is the "adjuster" and how do I adjust mine to see if I can get it to make sound...Only one of my horns makes sound.
Tks.
ZRWON is offline   Reply With Quote
Old 07-02-2009, 12:35 AM   #12
Willcox Corvette
Premium Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Willcox Corvette's Avatar
On the side of the horn there is a torque head screw, this is the adjustment.
However, I would replace the horn. If a horn is blowing even the littlest it eliminates the contact and the relay. They go bad over time and the diaphragm will rust inside, the sides will separate. The electro magnet inside the horn has points in it similar to the old ignition points in a car and they will fail over time. Rebuilding a horn. .. .Been there done that on a 60! Not an easy job.
Willcox Inc.
Willcox Corvette is offline   Reply With Quote
Old 07-02-2009, 07:57 AM   #13
PAINTER MAN
CF Senior Member
If you have the VAT's system, see if they will blow when activated. My 86 had a problem similar to yours. The horns would work though when using the VAT's.
The horns are grounded through the turn signal lever. I replace the lever and now the horns work fine.
PAINTER MAN is offline   Reply With Quote
Old 07-02-2009, 08:55 AM   #14
runner140*
CF Senior Member
Support Corvetteforum!
runner140*'s Avatar
Sound like you got a pair...buy some aftermarkets. I purchased a set
of Wolo's a couple of years ago.....what a diff.
They look like this:
runner140* is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • 86 Horn "barely" working?
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Horn jechler C4 General Discussion 1 11-20-2014 02:37 PM
    how to remove C4 horn button 1986 Convertible rjs86vette C4 Tech/Performance 3 09-18-2014 04:01 AM
    Horn troubleshooting tips Tally Ho C3 Tech/Performance 7 07-25-2011 01:35 AM
    My Horn Honks Without Pressing The Horn Button! Poodle Shark C3 General 8 11-17-2006 01:33 AM
    Horn No Blow MR.WaynesWorld C4 General Discussion 1 08-01-2006 09:48 AM
    Tags
    86, 86corvette, audible, barely, car, corvette, horn, horns, makes, npose, replace, sound, sounds, working
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
