'93 Will not start...code 16
Old 09-23-2009, 10:19 PM
tco43
5th Gear
tco43's Avatar
Default '93 Will not start...code 16
Our 93 will not run, will not start. Engine spins over fine. Fuel pressure is 42-43 psi and stays there. Codes show the 16 code...distributor ignition system fault.
What do I do next?
Thanks. Paul.
Old 09-23-2009, 11:12 PM
TOO_HOTTVETTE
TOO_HOTTVETTE's Avatar
Opti?
Old 09-24-2009, 02:41 AM
tco43
5th Gear
tco43's Avatar
Yup.
Old 09-24-2009, 10:26 AM
Madmikeee
Madmikeee's Avatar
Location: Sometimes I wonder... why is that frisbee getting bigger? Then it hits me.
Cruise-In X Veteran
St. Jude Donor '06
Originally Posted by tco43
Yup.
just answered your own question then
Get yourself a new opti and waterpump with a 160deg thermostat and do them both at the same time
Old 09-24-2009, 11:55 AM
tco43
5th Gear
tco43's Avatar
I've been reading threads on the subject and understand what you're saying. The sensitivity to moisture seems to be an issue. We'll probably have the dealership do it(the car is low-mileage,mint).
On the thermostat--isn't 160 a tad low? What is original...185,215?
Thanks guys, for all the help.
Old 09-24-2009, 12:03 PM
aminnich
aminnich's Avatar
Original is 185 and if everything is stock just leave it that way. Shame to have to use a dealer as they will prrobably be around $1200, not counting a new WP. What area of the country are you in?
Old 09-24-2009, 12:05 PM
flynn508
flynn508's Avatar
original is 185; and do youself a favor and just dont ask. There are a million threads and/or opinions on installing the 160 degree t-stat. It will start yet another long and ugly battle on the forum between the guys that swear they get performace gains from it, and from the guys that think they are nuts. If you liked the way you ran with the stock t-stat; then just get a new one. JMO
Old 09-24-2009, 12:09 PM
tco43
5th Gear
tco43's Avatar
OK. Let's dodge the thermostat scuffle.
Again...thanks.
Old 09-24-2009, 12:10 PM
tco43
5th Gear
tco43's Avatar
We're in Racine, WI
Old 09-24-2009, 12:23 PM
aminnich
aminnich's Avatar
We're in Racine, WI
Definitely not close enough to me. Maybe check the local Vette clubs to find a good shop other than a dealer. Might save a few dollars.
To '93 Will not start...code 16
Quick Reply: '93 Will not start...code 16
