2009's almost over. Post your most recent C4 pic's & list what was done in 2009...
It's the 5th of December 2009, and so far, not a single flake of snow has fallen and I'm as happy as can be. The longer the ground stays snow-free, the longer I get to drive the 'Vette.
Thought it'd be nice to start a thread in which EVERYONE can post a few of their most recent C4 pic's and a list of mods/projects that you completed this year. Feel free to also list mods/projects you plan on doing in 2010.
(Please don't quote pictures )
I'll start off with mine...
Year and model: 1992 Corvette
Completed in 2009:
- Corsa exhaust
- Long tube headers
- Cut-lid and K&N
- PCMforless custom tune
- HD Electric water pump
- Complete ignition system overhaul (all Delco replacements)
- Bosch 3 injectors
- Racetronix 255 fuel pump
- New fue pressurel regulator and filter
- New sensors (TPS/IAC/02 sensors)
- T.B. Coolant bypass
- GoodYear GS-D3 315's out back
- Lowered the rear end
- Alpine head unit
- HydroCarbon radio bezel and console cover
Plans for 2010:
- 1.6 roller rockers and new valve springs
- 4.10 gears
- Adjustable front springs from VBP
- C5 front brake upgrade
- New speakers, a sub and an amp to finish off the audio system
- Replace a few weather-strips throughout
Feel free to add your pic's and info as well!!!
Completed in 2009:
- Corsa exhaust
- Long tube headers
- Cut-lid and K&N
- Bosch 3 injectors
- Alpine head unit
Plans for 2010:
- 4.10 gears
well... I just picked mine up 2 weeks ago..
previous owner within the last year:
-new starter
-fresh rubber
-opti, water pump and plug wires
-radiator
ME:
-brakes and a fluid flush
-spark plugs
-smog check passed and money wasted on sales tax to Ahnold
-fixed my console lid
-windshield wipers
-monroe shocks temporarily on to rebuild FX-3 bilsteins next year-black tape mod over warning light mod in effect.
-oil filter (I had the mobil 1 already)
-new starter
-fresh rubber
-radiator
ME:
-spark plugs
-windshield wipers
how do you keep the 315's from rubbing..especially lowered??? mine came with ZR1 rubber and I desperately want it back to stock size so I can hit corners harder without rubbing.
The car has ZR1 replica wheels with the GS off-set so they fit right in with no rubbing. The rear lowering bolts are adjustable and I lowered the rear just enough to get the gap between the tire and fender to match the front for a nice "flat" stance.
As it sits right now, I have no issues at all with rubbing. Perhaps next year when I lower my front (and thus, have to lower the rear even further) I may run into something, but right now, it fine. Sorry I couldn't be of more help to you
Location: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
My `87 The only thing I`ve added this year is the sawblades, a new Clarion radio with USB/Ipod controls, & had the rear clip repainted because of peeling clearcoat ( paint done by Fantastic collision, Levittown,Pa. Great job, & only cost $650 )
[IMG][/IMG]
[IMG][/IMG]
Oh Yeah- almost forgot, replacing every bulb I can with L.E.D`s
[IMG][/IMG]
[IMG][/IMG]
Rubbing has never been an issue on mine The car has ZR1 replica wheels with the GS off-set so they fit right in with no rubbing. The rear lowering bolts are adjustable and I lowered the rear just enough to get the gap between the tire and fender to match the front for a nice "flat" stance.
Big Mouth Air Dam, FIC bosch III injectors, SS brake lines, new rotors and hawk pads (going on tomorrow), custom ram air intake and license plate cover, and Michelin PS2s for better autoX times.
Okay... In 2009 I.....
PURCHASED THIS SEXY BEAST!!!
New opti
water pump
02 sensors
Intake gasket
Tranny and brake flush
Next year Im going to get.....
New weather stripping
brakes (C5 break system if I can afford it)
and honestly I'd love to have more than that done but I doubt i'll find the money for anything else.. Oh well...
Repairs:
Broken left spindle April 4 - destroyed halfshaft, U joints, and speed sensor. Repaired and back on the road by April 23.
Broken left U-joint April 24. destroyed halfshaft , other U-joint, D44 gears and center section. Back on the road by May 16.
Upgrades: During first repairs, replaced all interior leather and carpeting Car looks like new on inside. Cleaned engine.
Photos:
Photos:
New for 2009:
Newmancarcreations Complete Rearend with 3.73s
SPEC Stage 2+ Clutch and Alum. Flywheel
B&M Ripper Shifter
DRM Camber and Trailing Arm brackets
LPE License Plate Frame and chrome letter on bumper.
2010 plans: Get Traction!
B&M Ripper Shifter
I took these more recently (bad pics)
installed 09'
-Super Ram intake
-BOSH 3 injectors
-96' Hardtop
-96' GS Wheels/ tires
-DynoMax Mufflers
Next Year install my
-Richmond 3.75 gears
-Trans cooler
-shift kit
-Mitch Piper Custom 6 point rollbar
installed 09'
-Super Ram intake
-BOSH 3 injectors
-96' Hardtop
-DynoMax Mufflers
-Trans cooler
-shift kit
Recent Pics:
Just bought her in July, so changed fluids, plugs, cap, rotor, and coil.
I've got some big plans for the winter months:
Port crossfire intake and heads
roller valve train
new exhaust with long tube headers
ebl flash ecm
some interior work
I'm looking forward to turning some wrenches
roller valve train
ebl flash ecm
some interior work
Pics... I've posted enough, but here ya go.
What was done to it this year?
A lot:
- Installed Kirkey 17" road race seats on custom designed and made brackets with I/O port back braces.
- Installed Simpson 6 point harnesses
- Removed radio and climate controls and replaced with aluminum blanks.
- Painted interior and added heat shielding
- Went through 2 ignitions and 3 coils. Ended up with a MSD digital 7 and a HVC pro power coil.
- Changed over to Champion S55C "race" plugs
- New aluminum pedals
- Meziere electric water pump after eating 2 mechanical ones
- added Moroso 3qt sump
- added Canton oil cooler
- upgraded to Wilwood SL6R brakes, cooling ducts, and rotors
- made my GS fender stripes
...and more than I care to remember because all of it equals money, blood, and sweat.
A lot:
My big project for the Summer was to build onto the shop so I had room to park some of the Vettes inside over the Winter. Now I'll have room to restore my 90 Morrison World Challenge car in time for the NCM C4 Bash in May 2010.
I havent even had mine for two years yet, but here is whats gone on this year.
Interior: new radio bezel, shift plate and door bezels done in a brushed aluminum look by pat scorzetti, along with a logo on the breadbox delete in the same finnish. Momo steering wheel, shift boot. Kenwood bt 838-U headunit that has bluetooth and usb. used speaker grilles and gauge cluster that are in much better shape than my originals
Engine: braided steel fuel lines, 160* thermostat, ported edelbrock runners ported stock base and plenum all painted black with silver accents, edelbrock valve covers.
Exterior: mirror finish rear letter, pulled all the emblems off and started sanding.
Plans for 2010: Finnish paint, black zr1 wheels,
Gosh, I shutter to think about this. Spending thousands on a car worth only a few thousand? I keep asking myself why. I know why, because my wife won't let me have a C6!
This year's list:
* True dual exhaust conversion with new high flow cats.
* New Bosch-3 30 lb injectors from FIC - definitely worthwhile!
* A new set of pulleys for the blower from Greg @ BlowerWorks
* Tune up, new wires, plugs, etc.
* New chip setup so I can do my own tunes on the fly
* Ditched the Blose and replaced with a Kenwood double din and four new speakers and sub - Definitely makes cruising a pleasure again!
* New set of sill guards
Overall, I think I put in almost as much in these upgrades as I could sell the car for these days!
This year's list:
Just bought my 96 in the end of June, and put it away the first week of November after puting almost 8000 miles on it.
-New bumper, headlight housing and paint on the hood after a 65 mph
encounter with Bambi
-Replaced tires
-Alignment
-Replaced water pump
-Found this forum
Next year
-Replace brakes
-Install HID fog lights
-Clean carpet
-Polish
-Weather Strip
-"Men Behaving Badly" road trip with my dad
-Replaced tires
-Alignment
-Found this forum
Next year
-Replace brakes
-Clean carpet
-Polish
-Weather Strip
i wouldnt say these were mods lol more like replacements/fixes
-heater core
-radiator
-weather stripping
-painted the calipers black
-Hella headlight conversion
next year
LONG TUBE HEADERS!
-heater core
-radiator
-weather stripping
next year
LONG TUBE HEADERS!
