Battery tender vs trickle charger
I have a Sears 10Amp trickle charger. would this serve the same purpose as one of those battery tenders ? if not could I just turn the trickle charger on say once a week or at some other interval ?
thanks and Merry Xmas.
no, battery chargers constantly charge, a tender is a float charger that will recharge only when the battery drains some, I think about 10 mA.
You don't want a charger on fulltime, tender will be okay.
Flatulent Dwarf
My other perversion is long distance motorcycle touring.....The Battery Tender folks are very well known in that arena for consistent performance and reliability. Spend the money, you won't regret it. About 40 bucks at Cycle Gear.com or online at other motorcycle outlets. They may be available other places too....but I know about the scooter supply houses.
later, tiny
later, tiny
Location: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
I always have a battery tender hooked to my `Vette. If you use the name brand "battery tender or battery tender jr.", you will pay $40 or more. I got mine from Harbor Freight for $11, 3 years ago & it still works fine.
Joe
You just can't go wrong.
Flatulent Dwarf
http://batterytender.com/resources/f...s.htm#answer10
later, tiny
That is not the same function as a Battery Tender....do a little research on the BT and you will see why. Here is a link to the Battery Tender website.
later, tiny
later, tiny
The OP asked if there was a way to use the equipment he has. I provided an option that has served me well for many years.
Keep in mind
CHURCHKEY makes a point
Vehicle batteries are designed internally to be discharged and charged daily (daily vehicle use). Right
A trickle 1amp or 2 amp charger with lite sensitive timer running for 1 or 2 hrs daily will come as close as anything to daily use.(I put a nite lite inline to confirm its working)
This is based on the assumption that most batteries will discharge and go flat in 4 - 6 weeks without use.
I think batteries will rot internally if not warmed up daily with some discharge and charge action.
Any battery experts care to comment on this laymans opinion.
I have used the BT Jr for the last 4 years and had very good luck with it. Plug it in and forget about it. Being a fireman, I am not a big fan of leaving an automatic timer hooked up in my garage. Might be a little over cautious, but that is just me.
I use a battery tender in the winter. I switch one tender between the Corvette and my two motorcycles. Usually I'll leave it one vehicle for about a week and then switch it to the next one. Works fine.
