Brake options
Use really good pads, they will make a world of difference. Carbotech is good just naming one.
For an older car, I would recommend braided SS hose. After that, THOROUGHLY cleaned calipers, brake pads and rotors.
Received 1,753 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
If you want you can upgrade to the J55 13" C4 brakes for a lot less than the C5 conversion. Also, good pads, clean calipers (good seals and grease on guide pins) will make a world of difference, like others mentioned.
