relay location?
Cruising
relay location?
can anyone tell me where the relay that controls the headlights flipping is located? one of mine flips with the switch and the other i have to do manually. ran power to both separate and they flip.
thanks, dan
thanks, dan
If your car is the 84 listed in your profile the head light relay box is located drivers side in front area mounted to inside of wheel well, if I remember right. You have to open the box there should be 3 relays there, they should all be the same. Follow your power wires from the motor they will lead to the box. Hope this helps. In the future list your car year in the posts makes it easier to help.
