Is this scanner OK?
Is this scanner OK?
I can get this free crom my Credit Card company using points. It's the only one they have.
Good/Bad?ugly?
Equus 3140 Innova Diagnostic Code Scanner for OBDI and OBDII Vehicles
Provides SAE enhanced Live Data - views, records, and plays back live PCM data streams
Designed to retrieve diagnostic codes in all OBD2 (1996 and newer) and some of the most popular OBD1 (1981 to 1995) vehicles
Communicates with all OBD 2 protocols: C.A.N. (Controller Area Network), ISO 9141, J1850PWM, J1850VPW, KWP 2000 ISO 14230-4
Displays Freeze Frame Data
Unique patented all-in-one screen display and LED display make diagnosis quick and easy
Equus Ford Code Reader Extension Cable for EPI3145 The Equus 3140 Innova Dignostic Code Scanner is an enhanced scan tool that is loaded with many professional features. If you are new to diagnostic scanners, this handy tool connects to your vehicle, scans various parts of your car, truck or SUV, and retrieves a list of diagnostic trouble codes (DTCs) and code definitions from your vehicle's computer. But even if you're a veteran to scanners and auto repair, you'll be impressed with the new functionality that Equus has added to the 3140. This device not only scans your vehicle, it also allows you to freeze-frame live timing and pinpoint your vehicle's problem. Instead of having to recreate a scenario over and over again, you can now playback the timing to scrutinize all the data and make a clear diagnosis. Combine this with Internet connectivity and the ability to interface with a PC, and you have a powerful, professional diagnostic scanner in the palm of your hand.
As government agencies establish more stringent emission laws, vehicles continue to become more sophisticated for maintenance and repairs, forcing professional mechanics, DIYers, and consumers alike to find easy-to-use tools for diagnosing their vehicles. Many tools have already been developed to access these powerful on-board vehicle computers, but the Equus tool is particularly simple to use and surprisingly affordable. It is designed to be used by almost anyone, from the weekend mechanic to the ASE master technician. The 3140 Diagnostic Code Scanner can retrieve diagnostic codes in all OBD II (1996 and newer) and some of the most popular OBD I (1982 to 1995) vehicles. The scanner features a unique, patented all-in-one LCD screen that shows 25 parameters at once without the need to scroll through time consuming menus. Separate LED indicators located below the screen provide quick OBD I/M emissions checks; so you'll know if you're ready to pass those ever-increasingly stringent laws. Equus built the 3140 to display on-screen DTC definitions and user interfaces in English, Spanish, or French, and the trilingual language selection is accessed via a simple menu command. This device can store diagnostic codes in its memory for off-car review and analysis. Additionally, you can connect the 3140 to your PC with the included cables and software to generate, print, and save detailed diagnostic reports--and even update the scanner via the Internet.
The 3140 links to all OBD II protocols including CAN (Controller Area Network). The tool captures and displays freeze frame data that will help you pinpoint and troubleshoot any problem. This device is equipped to retrieve the following OBD II diagnostic trouble codes (DTCs): Generic Codes (P0, P2, P3, and U0) and Manufacturer Specific Codes (P1, P3, and U1). In addition, the tool provides live data (view, record, and playback live PCM data streams), bi-directional testing, vehicle ID capture, and O2 sensor results.
The Equus 3140 can also perform diagnostic scans for the following OBD I vehicles:
General Motors: all 1982-1993, and some 1994-1995 models
Ford, Lincoln, and Mercury: 1983-1995 models with EEC-IV systems (KOEO, KOER, timing check, cylinder balance test, output state test, and wiggle test)
Toyota/Lexus: 1991-1995
Chrysler/Dodge/Plymouth: 1984-1995
Jeep: 1993-1995
Warranty
Limited one-year warranty.
What's in the Box
Equus 3140 Diagnostic Code Scanner, OBD-PC link software, cables, storage case, and user's manual.
Good/Bad?ugly?
Jeep: 1993-1995
Warranty
What's in the Box
No personal experience, but it sounds more capable than my Auto Xray 6000 and most other consumer grade scan tools I am familiar with. Bidirectional function is rare on such tools and is normally only found on professional tools with a much higher price.
Understand that you will only have access to the ECM unlike the Tech 1 or pro grade scanners that can read codes and data from other computers such as CCM, ABS etc., but since you can get the tool using points and will have no cash outlay give it a try and be sure to post a report after using it for others who may be interested.
Hmmm, doesn't comm w/the CCM huh..Hmmm.
What "decription" should I look for in one tht would comm. w/the CCM too?
I have more CC points than your avg. bear and my CC company will get me just about anything I want...so it's not the pionts Im worried about. I'd rather get the best I can.
This is the only "stock" scanner they offer, I can however do a custom buy, it'll require more points but thats not an issue.
