spare tire size
Old 04-16-2010, 07:18 AM
jon0108
jon0108's Avatar
Default spare tire size
I have an 86 coupe that came stock with 16" wheels and a 155/80/16 spare tire. I put 17" wheels and tires on it, 275/40/17. My question is that I'm searching for another spare tire to replace my current one. Can I go with a 155/70/17, which was the stock size on later vettes with 17" wheels? I checked on a tire size website and it looks like both sizes are somewhat similar in size. I'm just worried that the 17" spare from another year wont clear the calipers.
Old 04-16-2010, 09:16 AM
RollaMo-LT4
RollaMo-LT4's Avatar
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'19-'20-'21-'22-'23
Where have you found a T155/70-17 spare tire at?
From what I've head, they are no longer available anywhere.
But if you've got one, it should fit fine. If your 16" rim fit, I can't imagine having any issues with the 17" rim clearing the calipers.
Remember, these are "temporary" spares. Only meant to get you to the next tire repair center.
Old 04-16-2010, 10:09 AM
jon0108
jon0108's Avatar
I havent found a T155/70-17. I was hoping to stumble across one. I guess I'm better off looking for the 155/80-16 then.
Old 04-16-2010, 12:54 PM
aklim
aklim's Avatar
Received 2,230 Likes on 1,942 Posts
IIRC, I had to get mine from Tire Rack. You have to call them to get it.
Old 04-16-2010, 05:28 PM
pologreen1
pologreen1's Avatar
I think some use honda tires or something like that. There was a couple threads on this.
Old 04-16-2010, 05:34 PM
jon0108
jon0108's Avatar
i tried searching but cant come up with anything
Old 04-16-2010, 06:03 PM
floridamale
floridamale's Avatar
Your 275/40/17 have a smaller overall diameter then the 255/40/16 tires that were stock, so using the 16in spare should not be a problem. difference is 3/10ths of a inch. You need to be matching overall height not wheel size you can only drive on them a 100 miles or so anyways and below 50 mph I believe.
Here is the thread you were looking for
http://forums.corvetteforum.com/c4-g...tire-work.html
Old 04-16-2010, 06:18 PM
jon0108
jon0108's Avatar
thanks. Guess I'll just keep my current stock 16" spare. I was just concerned about it being 24 years old. I just checked the air pressure in it a couple of weeks ago and brought it up to 60 psi's. Lets see if it holds. If not I'll have it demounted and clean up the rim and remount. It is kind of dry rotted though. Anyway,just renewed my AAA today
To spare tire size
Quick Reply: spare tire size
