Why is the top of my door panel loose?
The window sill is off, ive tried to get it back over, and done it, but when i shut the door it just pops off. Is this common? What do i do to get it fixed? If i need a door panel where do i get one? Any help would be great!!
Roadster Madness. 😠
Received 1,510 Likes
St. Jude Donor '13, '20-'21
I then took it to an upholstry place, 101 Upholstry. He showed me about a 3/4 inch tear at the top, by the where the top meets the rear of the drivers window. He took it off, glued it, and charged me $25. Two years later and it still stays on.
you have to reinforce the broken ribs I used sheet metal and pop rivits and also put a self cutting washer screw through the side of the panel through the door so it can not lift up and pop off again paint screw interior color
http://forums.corvetteforum.com/c4-g...panel-fix.html
Good luck!
