Distilled water and antifreeze
Distilled!!!!!!!!!!
Distilled water is pretty cheap (about a buck a gallon at any large grocery store) so using it for flushing won't cost a bunch. And you will only need a few gallons for the final 50-50 mix when the new coolant goes in.
Get 3 gallons of concentrate and 3 gallons of distilled. Pour in one gallon of each into the cooling system and mix the remaining. Use that mix to complete the fill and adding to the lower overflow tank. You will have some left over for whenever it may be needed.
Well personally I think the distilled water falls into the same camp as changing your oil every 3000 miles...IMHO overkill.
I understand the logic behind using distilled water, but can't say I've ever had a problem using water from a tap...then again I'm on a well and my water is good to begin with so maybe my argument is worthless .
You can also use the water from a dehumidifier if you have one, that's distilled I believe.
You obviously don't live where the water is hard.
If I didn't use distilled, the rad would have stalagmites.
Distilled is cheap. The inside of the radiator still looks
brand new after 23 years.
We don't drink our water here so much as we chew it.
Distilled water is cheap insurance.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Distilled or Ionized.
Tap water boils at 212 F
Use the stove, try it....
The way I flushed mine is dumped the coolant from the radiator and block.
Filled with distilled.
Ran for a few minutes or so after the thermostat opened.
Let cool.
Dumped the radiator and block.
Then just started dumping and filling the radiator after running it for a few minutes or so after the thermostat opened.
After I got tired of doing that. I dumped the radiator and filled with straight antifreeze.
While running engine I kept filling the radiator with straight antifreeze till I had dumped in 7 quarts of antifreeze.
Then I started filling with distilled and burped it.
I used Zerex G-05 antifreeze. Should be good for 3 years. The green stuff, they recommend changing every year.
Let cool.
Let cool.
Let cool.
