Need Help!!!!New C4 owner...right turn signal not working
Anyone know why all my lights are working, but when I signal right the lights come on, but they don't signal. My turn signal inside goes on as well but just stays on and does not blink.
I just put two new front turn signal lights in, because the right one appeared to be out.
I had this happen to me. Mine was a short in the wire harness at the front right running light if I can remember correctly. I noticed it after replacing a fog lamp so I knew it had to be around there. I isolated it by moving the jiggling the harness and connectors for the right side markers, fog lights and running lights. Hope this helps
Put your turn signals on for each side or put your hazard lights on and walk around the car to see if any aren't flashing. If all lights are flashing but 1 or 2, replace the bad bulbs that aren't flashing or check the sockets for crud..
If nothing blinks or they blink real slow, replace the flasher - $5. On a C4, it should be behind the center display where your check engine light is.
Navigator
same somewhat problem
This is my first post...
Im having a problem along those lines, my driver blinker works fine when the headlights are OFF, for the passenger blinkers, all lights come on in the rear minus the rear side lights though it does flash. when i turn the headlights on they stop flashing all together, and the dash dims as well as the AC control lights flash in the opposite timing. The hazards work and i just replaced the third light socket and light b/c the old one was rusted in. So the right blinker stops flashing when the headlights are on, but when off all the lights flash. Think it may be bad wiring job? or the flasher.. checked to make sure light was in all the way and tight and it is.
Good luck
Navigator
the location where all the grounds seems to be fine, but like i said i am not familiar with electrical, will i be able to see a problem or need to jiggle the wires around to see if it stops? i isolated which wire is the problem when i changed the socket, it is the black ground but dunno where it is from there.
FLASHER OR SWITCH or BULB ??
Yes in my case...all hazards work and blinking just fine. As I mentioned the right side blinker bulbs (front and back) do not blink but they stay on, the green dash indicator light also does the same, stays on.
Before I tear out the dash I want to make sure someone else out there had the same situtation.
Max
Max
Problem solved {Flasher } New problem Help !
Now I have a new one. When I took down the under dash cover I noticed coolant leaking from a black box up by the firewall. Please help.
Max
69rag and C4boy got it right, it was the turn signal flasher, Thank You guys. I had an Idea that was the problem....I needed confrimation before I went through the trouble of uncovering the right underdash cover and hunted for the well hidden flasher.
Max
Max
