C4 Frame braces
Old 06-27-2010, 06:48 PM
corvetteronw
Support Corvetteforum!
corvetteronw's Avatar
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Default C4 Frame braces
Here is a pic of the kit. It also comes with bolts to secure the brackets to your frame. Each 86 to 96 coupe and vert has threaded holes in the front of the frame already for the X braces. This kit uses these front holes and uses the existing bolts at the rear for the other brackets.
As designed by Gordon Killebrew and marketed by Jason Francis of www.vette2vette.com
Jason said they will be doing a kit for the 84/85 later. One of the members over at Corvette Guru will be setting up a group purchase at a discounted price. I do not know what that price will be.
Once again, before anyone rags on me: I do not get a commission on these and I have no commercial interest in them other than getting a nice price break on this early set and trying to publish an article in Corvette Enthusiast magazine of my home install.
Here they are installed on a 90 ZR1. Thanks to Mid America for graciously letting us use their exhaust install lift right in the middle of a very busy Saturday for them.
This is the set that I will be installing in my home garage:
Old 06-27-2010, 07:51 PM
BAM92
BAM92's Avatar
With out cross type bracing, how well does it help with cowl shake with top off?
Old 06-27-2010, 08:00 PM
Bondami
Bondami's Avatar
Location: Southside of Western Norte Americano State of Confusion, ColoFornia
St. Jude '13
Old 06-27-2010, 09:11 PM
corvetteronw
Cruise-In VIII
Jeff from the Corvette Guru Forum has a ZR1 that has a prototype model on it. His model does not have the nut welded to the front end of the bar so he has to tighten the tube by hand. He says it has helped a lot but he still needs to tighten it more. A pipe wrench should do the trick.
Old 06-27-2010, 09:20 PM
StealthLT4
StealthLT4's Avatar
Doesn't the frame have HUGE rails that run exactly where these do? That you have to step over to get into the car? Sorry I just don't understand how these would help at all without triangulating the frame.
rocco16 (05-07-2016)
Old 06-27-2010, 09:30 PM
-=Jeff=-
-=Jeff=-'s Avatar
I don't either but they work, I just need to get them set perfect.. I adjusted them today.. even better then the last 3 days, but I think the Passenger side still needs adjusting.. I will see how my week goes for doing that and driving it some more
Old 06-27-2010, 09:32 PM
pologreen1
pologreen1's Avatar
Well, if these help at all on a coupe, I can only imagine the difference the X frame brace from R&D makes on the car.
Old 06-27-2010, 09:38 PM
black88z51
black88z51's Avatar
I see 4 mounting bolts on the rears but only 1 on the front brackets. There must be 2 on each front bracket right? to lock it from twisting about the bolt. how much does the system weigh? The intent here is to prevent the frame from bowing right?
Old 06-27-2010, 10:14 PM
-=Jeff=-
-=Jeff=-'s Avatar
other way around.. the 4 bolt brackets are the front ones
Old 06-27-2010, 10:16 PM
-=Jeff=-
-=Jeff=-'s Avatar
Originally Posted by corvetteronw
to clarify, the brackets towards the top in this picture are the Rear brackets
the longer flatter ones are for the front
Old 06-27-2010, 11:49 PM
dogfish246
dogfish246's Avatar
Interesting... But, I dont get how they work either...
Old 06-27-2010, 11:55 PM
corvetteronw
Cruise-In VIII
The Forum parking lot was flooded out at the show on Saturday so we had to park about 900 yards from the vendor area. I carried the entire set to my car along with a my camera bag and a few other things.
I am guessing they weigh about 25#. I'll put them on a scale tomorrow.
Old 06-28-2010, 12:10 AM
vettenut94
vettenut94's Avatar
On the adjustment of these is the object to push the ends apart or to pull them together? & is there only one mounting bolt to hold the rear bracket on?
Old 06-28-2010, 01:18 AM
Eakster
Eakster's Avatar
My car suffers from horizontal twisting of the body, espec with top off as we all know. If it was bending longitudinally I think I wouldn't drive it
Old 06-28-2010, 02:08 AM
littlesk8cracker
littlesk8cracker's Avatar
agreed, those humps are there for something. this is along the same idea as frame rail connectors for my old third gen, except the c4 seems to already have these
Old 06-28-2010, 05:39 AM
enventr
enventr's Avatar
will this be as rigid as the X frame ?
Old 06-28-2010, 08:29 AM
corvetteronw
Cruise-In VIII
Weighed them on the bathroom scale today. Very unscientific weight of 19#.
To C4 Frame braces
Old 06-28-2010, 08:31 AM
shakedown067
shakedown067's Avatar
St. Jude Donor '12-'13
I read somewhere that Gordon Killebrew actually designed these during the C4 run and suggested adding it on. He was denied by GM brass as they didn't want to add any further cost to the car.
I still don't get it either though...
Old 06-28-2010, 08:32 AM
Calderone
Calderone's Avatar
this are very interesting, what's the overall effect ?
Old 06-28-2010, 06:59 PM
BAM92
BAM92's Avatar
Your third gen was a unibody. Therefore people use subframe connectors to connect the front and rear subframes together to make it more rigid. Corvette is full frame.
Quick Reply: C4 Frame braces
