***The Ultimate C4 DIY thread.... write ups w/ pics..***
Old 04-14-2013, 09:00 AM
  #61
corvetteronw
Support Corvetteforum!
corvetteronw's Avatar
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Default L98 Vacuum Lines
Old 04-14-2013, 09:04 AM
  #62
corvetteronw
Cruise-In VIII
Default Throttle Body Bypass pics
Old 09-08-2013, 03:17 AM
  #63
Sassman
Sassman's Avatar
I'm new to the forum, as well as being a new owner of an old '94 C4. The video for fixing the headlight motor gear couldn't have come at a better time, for my drivers side light just started making "the noise". I've ordered the bushings and am ready to have my laptop by my side, with the video playing.
Old 04-06-2014, 12:46 AM
  #64
BlackRaTT
BlackRaTT's Avatar
Default Main link is broken please fix
The link at the start of the thread for the majority of the how to's is broken.
Old 11-29-2014, 12:59 PM
  #65
88C4convertible
88C4convertible's Avatar
Default how to's
what the last guy said, link broken on first page, I know it's old, isn't this stuff archived somewhere. Oh yeah, new owner of an 88 C4 Convertible 4x3
update...found the working link-->https://www.corvetteforum.com/forums...go-thread.html
Old 12-16-2014, 09:32 PM
  #66
Stephane Olivier
1st Gear
Stephane Olivier's Avatar
Default color wiring for headlight motor c4 85?or fuse ?
hi
i have a 85 c4 that i am rebuilding and i just put new headlights but i couln't find the colors of the wiring in between the motor and the headlight in the manual?
so i hot wire it and it works but driver is perfect but now passenger side is not opening anymore ?
what are the fuse for the right side ?
or what are the colors of the wires ?
sorry i got confused in the wires
thxs if someone can help me
Old 01-13-2015, 11:06 AM
  #67
86C4Z51
86C4Z51's Avatar
Subscribe -- Thanks to everyone who posts this somewhat esoteric stuff on the forum.
Old 02-19-2015, 12:51 AM
  #68
Silverfox1
Silverfox1's Avatar
Default Service Soon Light
Originally Posted by socalman
Engine Trouble Codes:
1984:
code 13 =1 flash followed by 3 flashes =>oxygen sensor
code 14 =1 flash followed by 4 flashes =>coolant sensor
code 15 =1 flash followed by 5 flashes =>coolant sensor
code 21 = 2 flashes followed by 1 flash =>throttle position sensor
code 22 = 2 flashes followed by 2 flashes=> throttle position sensor
code 23 = 2 flashes followed by 3 flashes=> manifold air temp sensor
code 24 = 2 flashes followed by 4 flashes=> vehicle speed sensor
code 25 = 2 flashes followed by 5 flashes=> manifold air temp sensor
code 32 =>egr system
code 33 =>map sensor
code 34 =>maf sensor
code 35 => idle air control
code 41 => cylinder select error
code 42 => electronic spark control
code 43 => electronic spark control
code 44 => lean exhaust
code 45 => rich exhaust
code 51 => PROM
code 52 => fuel calpak
code 53 => system over voltage
code 54 => fuel pump circuit
code 55 => ecm
code 62 => oil temp
1985-1991
Code #12: Normal No Codes.
Code #13: Open Oxygen Sensor Circuit.
Code #14: Coolant Sensor Circuit Low.
Code #15: Coolant Sensor Circuit High.
Code #21: Throttle Position Sensor High.
Code #22: Throttle Position Sensor Low.
Code #23: Manifold Air Temperature Circuit High.
Code #24: Vehicle Speed Sensor.
Code #25: Manifold Air Temperature Circuit Low.
Code #32: EGR System Failure.
Code #33: Mass Air Flow Sensor High.
Code #34: Mass Air Flow Sensor Low.
Code #36: Mas Air Flow Sensor Burn-Off Function Fault.
Code #41: Cylinder Select Error.
Code #42: Electronic Spark Timing.
Code #43: Electronic Spark Control.
Code #44: Lean Exhaust indication.
Code #45: Rich Exhaust Indication.
Code #46: Vehicle Anti Theft Fault.
Code #51: Faulty Mem-Cal.
Code #52: Fuel Calpak Missing.
Code #52(1990-91 Corvette Only): Engine Oil Temperature Sensor Low.
Code #53: System Over Voltage.
Code #54: Fuel Pump Circuit Low Voltage.
Code #55: Defective ECM.
Code #62: Engine Oil Temperature Sensor Circuit High
1992-1993
Code #13: Left Oxygen Sensor Circuit.
Code #14: Coolant Temperature Sensor Circuit High.
Code #15: Coolant Temperature Sensor Circuit Low.
Code #16: Opti-Spark Ignition Timing System.( Low Pulse)
Code #21: Throttle Position Sensor Circuit High.
Code #22: Throttle Position Sensor Circuit Low.
Code #23: Intake Air Temperature Sensor Circuit Low.
Code #24: Vehicle Speed Sensor Circuit.
Code #25: Intake Temperature Sensor Circuit High.
Code #26: Quad-Driver Module #1 Circuit.
Code #27: Quad-Driver Module #2 Circuit.
Code #28: Quad-Driver Module #3 Circuit.
Code #32: Exhaust Gas Recirclation Circuit.
Code #33: Manifold Absolute Pressure Sensor Circuit Low.
Code #34: Manifold Absolute Pressure Sensor Circuit High.
Code #36: Opti-Spark Ignition Timing System. (High Resolution Pulse.)
Code #41: Electronic Spark Timing Circuit Open.
Code #42: Electronic Spark Timing Circuit Grounded.
Code# 43: Electronic Spark Control Circuit.
Code #44: Left Oxygen Sensor Circuit Lean.
Code #45: Left Oxygen Sensor Circuit Rich.
Code #51: Mem-Cal Error.
Code #52: Engine Oil Temperature Sensor Circuit Low.
Code #53: System Voltage.
Code #55: Fuel Lean Monitor.
Code #56: Vacuum Sensor Circuit.
Code #61: Secondary Port Throttle Valve System.
Code #62: Engine Oil Temperature Sensor Circuit High.
Code #63: Right Oxygen Sensor Circuit Open.
Code #64: Right Oxygen Sensor Circuit Lean.
Code #65: Right Oxygen Sensor Circuit Rich.
Code #66: A/C Pressure Sensor Circuit Open.
Code #67: A/C Pressure Sensor Circuit. (Sensor or A/C Clutch Circuit Problem)
Code #68: A/C Relay Circuit Shorted.
Code #69: A/C Clutch Circuit.
Code #72: Gear Selector Switch Circuit.
1994-1996
DTC #11: Malfunction Indicator Lamp Circuit.
DTC #13: Bank #1 Heated Oxygen Sensor #1 Circuit:
DTC #14: Engine Coolant Temperature Sensor Circuit Voltage Low.
DTC #15: Engine Coolant Temperature Sensor Circuit Voltage High.
DTC #16: Distributor Ignition System Low Pulse.
DTC #18: Injector Circuit.
DTC #21: Throttle Position Sensor Circuit Voltage High.
DTC #22: Throttle Position Sensor Circuit Voltage Low.
DTC #23: Intake Temperature Sensor Circuit Voltage High.
DTC #24: Vehicle Speed Sensor Circuit.
DTC #25: Intake Air Temperature Sensor Circuit Voltage Low.
DTC #26: Evaporative Emission Canister Purge Solenoid Valve Circuit.
DTC #27: EGR Vacuum Control Signal Solenoid Valve Circuit.
DTC #28: Transmission Range Pressure Switch Assembly Fault.
DTC #29: Secondary Air Injection Pump Circuit.
DTC #32: Exhaust Gas Recalculation.
DTC #33: Manifold Absolute Pressure Sensor Circuit High.
DTC #34: Manifold Absolute Pressure Sensor Circuit Low.
DTC #36: Distributor Ignition System High Pulse.
DTC #37: Brake Switch Stuck On.
DTC #38: Brake Switch Stuck Off.
DTC #41: Ignition Control Circuit Open.
DTC #42: Ignition Control Circuit Shorted.
DTC #43: Knock Sensor Circuit.
DTC #44: Bank 1 LF Heated Oxygen Sensor #1 Circuit Lean.
DTC #45: Bank 1 LF Heated Oxygen Sensor #1 Circuit Rich.
DTC #47: Knock Sensor Circuit Or Module Missing.
DTC #48: Mass Air Flow Sensor Circuit.
DTC #50: System Voltage Low.
DTC #51: EEPROM Programming Error.
DTC #52: Engine Oil Temperature Sensor Circuit Voltage Low.
DTC #53: System Voltage Low.
DTC #55: Fuel Lean Monitor.
DTC #58: Transmission Fluid Temperature Sensor Circuit Low.
DTC #59: Transmission Fluid Temperature Sensor Circuit High.
DTC #62: Engine Oil Temperature Sensor Circuit Voltage Low.
DTC #63: Bank 2 RF Heated Oxygen Sensor #1 Circuit Open.
DTC #64: Bank 2 RF Heated Oxygen Sensor #1 Circuit Lean.
DTC #65: Bank 2 RF Heated Oxygen Sensor #1 Circuit Rich.
DTC #66: A/C Refrigerant Pressure Sensor Circuit Open.
DTC #67: A/C Pressure Sensor Circuit Sensor or A/C Clutch.
DTC #68: A/C Relay Circuit.
DTC #69: A /C Clutch Circuit.
DTC #70: A/C Clutch Relay Driver Circuit.
DTC #72: Vehicle Speed Sensor Loss.
DTC #73: Pressure Control Solenoid Circuit Current Error.
DTC #74: Traction Control System Circuit Low.
DTC #75: Transmission System Voltage Low
DTC #77: Primary Cooling Fan Relay Control Circuit.
DTC #78: Secondary Cooling Fan Relay Control Circuit.
DTC #79: Transmission Fluid Overtemp.
DTC #80: Transmission Component Slipping.
DTC #81: Transmission 2-3 Shift Solenoid Circuit.
DTC #82: Transmission 1-2 Shift Solenoid Circuit.
DTC #83: Torque Converter Solenoid Voltage High.
DTC #84: 3-2 Control Solenoid Circuit.(Auto Only).
DTC #84: 2nd And 3rd Gear Blockout Relay Control Circuit.
DTC #85: Transmission TCC Stock On.
DTC #90: Transmission TCC Solenoid Circuit.
DTC #91: One To Four Upshift Lamp(Manual Only).
DTC #97: VSS Output Circuit.
DTC #98: Tachometer Output Signal Voltage Wrong.
Your research is amazing! So I have a '96 LT4 with just under 15,000mi that started flashing the light. I pinned the #4 & #12 & got the following:
C 12
1
7
9
A or R.
1.0
in that order. OK, I think I have something to work with. I just happen to have another '96 LT4 (32k mi) that runs perfectly, so I do that one for comparison. SAME codes.
I've reinstalled the gas cap a zillion times, put new gas in it, disconnected the battery which temporarily cleared the light, but it came on about an hour later while driving. I also cleaned the MAF filaments & connections on both sides - no change.
I have an OBD II scanner on the way & maybe that can isolate the problem better. Car runs strong & smooth, idles fine.
Any thoughts?
Appreciate the help.
Old 06-14-2016, 10:27 PM
  #69
Z51JEFF
Z51JEFF's Avatar
No LT5/ZR-1 tips,boooooooooo.
Old 07-06-2016, 07:27 PM
  #70
cherrypoppins
cherrypoppins's Avatar
Where is the 1984 Vette info the L83 and crossfire info.
Old 07-25-2016, 05:49 PM
  #71
A Peter C4
A Peter C4's Avatar
alot of info here
Old 03-26-2017, 11:16 PM
  #72
joelmatchpoint
joelmatchpoint's Avatar
Default Repairing Hush Panel (or other plastic trim pieces)
https://www.corvetteforum.com/forums...post1594390763
Nellyz888 (11-30-2020)
Old 03-30-2017, 11:12 AM
  #73
kael
kael's Avatar
Finalist 2020 C4 of the Year - Unmodified
Default How to side jack your C4
https://www.corvetteforum.com/forums...jack-a-c4.html
Save
Old 01-09-2018, 01:17 PM
  #74
johannes666
Cruising
johannes666's Avatar
Does some one know what is that whiteish connector that is loose at the moment? Its located at the above of passengers side kick panel. The wires that goes to that doesnt have any color it like see-thru.
Old 01-09-2018, 03:29 PM
  #75
johannes666
Cruising
Answer to myself. Its a speaker related.
Old 08-13-2018, 05:43 PM
  #76
f4av8r
4th Gear
f4av8r's Avatar
Default Removable top trouble
Hello all. I'm new here. One of my roof release bolts is FIRMLY stuck in place. I've tried an EZ out without success. Desperately need help. Thanks!!
Old 09-05-2018, 10:58 PM
  #77
gpierce
gpierce's Avatar
A member posted this today, good video to add for removing door handles
To ***The Ultimate C4 DIY thread.... write ups w/ pics..***
Old 10-01-2020, 09:14 PM
  #78
Vetted777
3rd Gear
Vetted777's Avatar
Default 1987 Corvette Repair
I am unsure of what this part is and it’s function. If anybody has any information it would be greatly appreciated! Thanks
The top one looks good but the bottom one looks broke. Is there a possibility it is still salvageable? & if not, do both need to be replaced?
Old 09-22-2022, 04:29 PM
  #79
Dacer Spears
Dacer Spears's Avatar
Added new section- Buyers Guide at top of page
Thank you!
Old 09-22-2022, 04:30 PM
  #80
Dacer Spears
Great! Thanks a lot, I need this.
Quick Reply: ***The Ultimate C4 DIY thread.... write ups w/ pics..***
