replacement shocks
08-07-2010, 04:27 PM
replacement shocks
We have a 96 CE with Z51 suspension. Would like to take some of the stiffness out of the ride. What shocks would help with this? Thanks
08-07-2010, 04:33 PM
St. Jude Donor '08-'09-'10-'11-'12-'13-'15
I run Koni Adjustable...Then you can make them as stiff as you like
08-07-2010, 04:42 PM
Normally I would say not buy Monroe or Gabriel shocks due to the reason they are not stiff like Bilstien. But in your case I would say go for those.
08-07-2010, 10:31 PM
Shocks
You can get DRM (Doug Rippie) to revalve your shocks with less compression or you can call and send direct to Bilstein.......
08-08-2010, 01:42 AM
KYB's are softer and less expensive than Bilsteins
