roof off shakes
You just hit another good point. The FSM says the body is bonded to the frame. Ok, what if over time and wear and tear the rear part of the body, somewhere, became unbonded in places. Now we have the body (much lighter) hopping around. I wonder in that case, by tying in The Steel Windshield frame, via the Targa top (fore/aft) if that would tame the body. In this case much less stress would be handled by the Targa, compared to trying to tame the frame flex ???
Consider this; If brand new C4's misbehaved so badly with the roof removed, there would have been recalls and people suing.
If the GM answer was that the Targa top must remain on the car, again people suing and forced buy backs. No, I truly believe this is a problem that developed with age and maybe certain types of usage.
8Valve
8Valve
Dave
8Vlave
When I take the roof off, my steering wheel shakes, the whole car feel less stiff by a wide margin. But I think the car looks better with the roof on, so I almost never take the damn thing off anyways.
In the past, I have done a search on this top on/off issue. I have read every post that search turns up. I have years of fab'ing and strength of materials as experience.
Simply put, I do not believe the Targa top stops all the flex and vibrations like many feel it does. Consider this;
In many of the searched posts I read, the poster's tell of serious body flex, windshield vibrations, steering wheel jumping back and forth. For this to happen, there is serious body flex !
Many of the C4's have the acrylic or glass tops with a small aluminum frame around the acrylic or glass. Consider the forces imposed on the Targa top as the car flexes. If this was all a real fact, that top would crack and break in a heartbeat. No way Acrylic or glass bonded in a aluminum frame is going to stiffen up the body an not break. There are other issues in play here, some cars have it while others dont with the top off. I would sure like to ride in a C4 that behaves poorly with the top off, then figure out why some do and some dont.
And if the flex was so bad without the top, GM for safety would have made the top not removable and had extra steel in the top for support.
8Valve
8Valve
good thread, im gonna look into the crossmembers and braces, im liking that targa brace. meanwhile im getting her on the lift to check body mounting adhesive
I have a '92 coupe with just under 37K on the clock. I found that when I replaced the original tires and shocks it made a BIG difference. Much less shake. Still a little just a bit on bumpy roads. From what I read on this topic, it really does vary from car to car.
I wish this forum was here in the early C4 Era. It would be interesting to read the archives on this topic....if such a topic even appeared. My feeling this is a age/usage issue that some cars develop. Anyone with access to recall info might be able to see if there were any recalls for this issue on the C4's, or any technical service bulletins issued.
8valve
8valve
Roof shakes
anyone else feel like the car is gonna rattle apart when they take off the roof panel? my car is tight as a drum with the roof on, as soon as i take it off i feel like the winshield is gonna fall off and the steering wheel gets a half a foot of side to side play(exagerating of corse) but very loose feeling none the less. anything can be done to correct this?
I had my roof off and the car was shaking all over the place. I took it to the shop and they said the tires were not balanced. They fixed that.... I thought that was the problem.. Got on highway and it was doing it again but not as bad.
The other day I took car to get windows tinted and I had to go threw Boston and went into a tunnel and the shaking stopped.. Thought that was odd.. But the air movement must have changed in the tunnel.
So after getting windows tinted.. The shop had to put top on... do to the tint.... On the way home the car ran great, no shaking... I'm guess it has something to do with the wind, and glass being off.. Must be throwing the cars balance off... It was very odd..
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
The top stiffens the body, that is unarguable.
8valve
8valve
And some have lead different lives.
This means some will still be tight and some will be loose.
#33
I'd buy a AFSB bar in a heart beat if I could find one. Mine is not as tight as I'd like without the top on.
Went
Went
#34
I bought a 93 new, and I now have a very well maintained 96 CE with 27K. I can say that they both were tighter with the tops on than with them off. The wheel and window would shake with the top off on bumpy roads. I took the top off my 96 and took some measurements then jacked it up, nothing changed. I still decided to buy the Vette2Vette frame braces. I put them on lose then went down my road for a reminder of what shook and how much. I then started adjusting them, after about three adjustments I would say its 75 to 80% better. I remeasured the roof opening and found that it had opened up about a 1/6" my roof now drops right in.
#35
Pro Mechanic
#36
My guess is that they put the car back where it was out of the factory. There were some marks one the top locating sockets that indicated that it had closed up a bit. FYI I have two journeymen's cards and a master motor cycles mechanics license so I do know a thing or two about how things work. I dont think bent is a good assumption they put the frame rails under tension to keep the sheet metal from flexing. If you take a car to a speed shop to get it to handle better one of the first things they do is weld up all the spot welded seams, the braces keep the spot welded sheet metal from flexing in a similar manner.
#37
Pro Mechanic
I beg to differ. I 'get it" how most things work pretty well too.
Welding up all the seams adds area of contact by closing up all the "holes" between spot welds. This allows the stampings to act as they were designed to; a monocoque. In practice the stamped pieces act differently, with spot welds that allow deformation between them. Welding doesn't put them in "compression", it doesn't change the shape or length in any meaningful way. All it does is increase the bonded surface area and allow the parts to act as they were designed to.
The bars put the front rail, rocker rail and rear wall spot welds into compression to increase stiffness. I don't have a "problem" with that, or doubt that it works for a subjective improvement (car "feels tighter").
My concern is the deformation of the points of contact at the spot welds. Why? Several people have posted that they installed the bars, tightened until snug and measured...then tightened to achieve the desired "feel", and measured again. I believe one person measured a 6mm difference. Where did the 6mm come from? Deformation of the spot welds at the ends of the rocker rails is the first thing that I think of. So, with that in mind, when I saw your post about measuring the hoop-to-windshield distance, before and after, it caught my attention. Something "bent" there...otherwise you wouldn't have seen a change in distance.
You're right that the car may have "sagged" over the years and you just brought it back into alignment, but I don't think that is what happened, because I don't think the C4 frame is so weak in bending, that it will "sag".
It's an interesting thing and it's cool that you did do some measuring before and after. As I've posted before; it sure would be cool if a structural engineer could weigh in on this, and shed some light as to what is really happening.
#38
Its interesting to see this thread has come back to life. Back in 8/18/2010 I made post #28. Now 6 years later, just a update on my 95. When my 95 comes out of winter layup, the roof comes off. The only time I put the roof on is when I go on a trip and dont have storage room in the back for the top. After 6 years, I still see no difference with roof on or off, and I push it hard on the black top mountain roads. The only difference I see is my hat trying to blow off with the roof off.
I seriously suggest that those with this handling issue with the roof off have a problem with the car. First, I would get it to a quality alignment shop and have everything checked. Hopefully a good shop will have the knowledge to go past the alignment and know other things to look for that might cause this problem. The General did not build a Corvette that would act badly with the roof off. You have a problem, apparently quite a few have the same problem, whatever it is.
8Valve
8Valve
#39
The side to side isn't that bad but it is annoying. Feels like bump steering that my fox body mustang suffered from except it jumps side to side constantly not just over bumps in a curve like the mustang.
#40
The first time that I took the top off my 95, I pulled over and walked around the car before I even got out of the neighborhood. It was a very noticeable difference.
Not undriveable by any means though.
FWIW- When the top is off for only a couple of days it goes back on easily. One time I left it off for the entire summer and it was a real bear to get back on in the fall.
Seems that verts would be worse without the halo and rear glass.
