Starter Problems '95 LT1 and Sticking Ignition Switch
C3 Corvette Enthusiast
My '95 must want some TLC and $$$.
The rack and pinion unit I ordered from Advance Auot fell through because none are availbale d/t lack of cores.
Over the past couple of months, I can turn the ignition switch and get a "grunt" from the starter but it doesn't turn. All lights stay on in the dash. I release the key and let it spring back, then turn it again and the starter engages. It's gone from doing this once a week to a couple of times a day. Before I start replacing the starter, I just want to be sure this is the problem.
Share your knowledge and wisdom with this poor and broke Corvette lover.
Also, the ignition switch has gotten harder and harder to turn, binding then releasing. How difficult is rebuilding the guts of the steering column? I want to do the best job while I'm in there, so how can I repair the "slop" in the steering wheel (when the sterring wheel is locked, there is some free play in turning and lateral movement.)
It sounds like a have a couple of projects for this winter, doesn't it?
BUMP
Hey people, I'm just asking a question to prevent re-inventing the wheel. I'm far from a C4 guru and I'm living on a limited budget, so needless parts swapping isn't something I can afford. Before some smartass says, "Use the SEARCH function," I have.
The symptoms I'm reporting about the way the starter is acting - is it [i]probably[/b] the starter not engaging correctly and binding, then working correctly the next time, or is it a bad starter, or possibly something else? AT least I'm not trying to blame the problem on VATS or the OPTI.
Corvette Central wants almost 200 bucks + shipping for a starter, Advance Auto sells them for $119.00. Any words of advice or warning before I start considering spending my hard-earned George Washingtons?
Thanks for any information that is helpful.
My ignition lock cylinder was sticking, so I sprayed some WD40 between the cylinder and column. I held a paper towel behind it to keep from getting WD40 everywhere. I would try to get the cylinder to rotate freely first.
As far as your steering column goes...the tilt mechanism is aluminum, and rebuild kits are long since discontinued. Over time, the holes in the tilt mechanism get wallowed out, thus getting sloppy. It's usually caused by using the steering wheel to pull yourself up out of the car.
If anybody has tried the repair that I suggested, please share with me your success/failure story.
You might want to borrow a known good battery and see if that get's rid og the problem.
*Sigh* Having to remove a body panel to replace the battery is new to me.
