Coil over conversion kits who has done this?
DRM has a Coil over conversion kits who has done this to his C4?
I want to know if i use the stock shocks will the ride be the same or stiffer?
I dont want to have a stiff ride, i want to be able to use it as a daily driver, what other coil overs conversion kits are out there that you would recomend?
Thanx
Thanx
Thanx
Thanx
Presumably you like the ride your car has currently?
For other kits, search around for QA1's. They have some advantages including being cheaper, and the shocks I believe have a narrower body. So you can use narrower springs and you don't have to relocate the shock mounts or sway bar. Of course it's a different shock, so I've no idea if it will be stiffer or softer than the Bilsteins given a similar spring rate.
Thanx
Thanx
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Do a search, there is plenty of info on this in this forum.
I did a QA1 coilover in my 96.
2017 C4 of Year
I do know they made the Vette better and yes, the ride is harsh and I love it. Its so harsh that the headliner I bought came off.
The roads are now cold and with summer tires I had to take it easy last time I went for a twisty run.
For the OT, the coilover installation is a joke, the modifications you will have to do are the ones that will slow you down. Read my thread...search is your friend.
DRM Front coilovers with Hyper Coils 425 Spring rate fronts
DRM Rear coilovers with Hyper coils 275 Spring rate rears
I also did the following
Total Poly Body bushing kit (Prophane kit)
Poly Sway bar links and end links etc etc
Guldstrand Front Sway bar relocation kit
Upper and Lower Ball joints (moog)
Rear dog bones replaced with Heim joint links.
