Leaking Oil Drain Plug?
Oil Pan Threads Stripped?
Some few years ago, when the dealership was changing my oil, the threads on the oil pan were stripped slightly. I didn't notice this until I began changing the oil myself. I had to take special precautions when replacing the drain plug ( doubling the washers seemed to work). I changed the oil a couple of weeks ago and noticed an oil leak at the "oil drain plug". I believe it's because of the stripped threads on the oil pan. Where can I purchase a "Self-tapping"/over size oil drain plug for my 1994 LT1 Corvette? Also, are any of you using the "Quik Valve" (no mess) drain plug apparatus? Does it work? My experience with oil changing has been quite messy. Thanks
$3 for a new drain plug and washer at the parts stores. It's a 1/2" X 20 thread.
The quick drain valves are not a good idea in my opinion. I mean come on. Is it that time consuming to crack loose a single drain bolt every several thousand miles anyway?
I like the GM copper-with-rubberized insert crush-type washers. About 3 bucks each and are rock solid seep-proof even with fully synthetic oils.
I have one of the quick-drain things. Not sure if there are different kinds, but mine is a ball-valve with a little lever on the top that operates the valve, and it spring-locks into the shut position. It's really nice; no tools, no dropping bolts, just jack the car up and turn the lever.
For the threads, not sure about how to fix that. You could try just running a tap through it, not sure of the thread pitch though,.
I believe any auto parts store should have them. Either go that route, or re-tap and use different size plug. Re-tapping is going to leave metal shavings, so extra care is needed to remove them before start-up. I also have been thinking about going to these valves. Have it on my lawn mower, and love it. I make my kids change my oil, and I always have to loosen the plug for them, what a pain, lol. No, it's not that hard to loosen a bolt every now and then, but why do it if you don't have to, right?!
Received 3,043 Likes
St. Jude Donor '05
Go to the 'bay and type 150528238294 in the search box
Contact seller (click on seller name) and see if they make one in the thread size you want.
