glass roof panel peeling on a 96'
6th Gear
anyone ever have or see this problem? it almost looks like a clear coat of some sort that got real hazy and is now peeling off. i can chip it away with my fingernail. anyone know of a fix for it? thanks.
Re: glass roof panel peeling on a 96' (SEEYOUINREARVIEW)
yeah thats happened to a few people here the only way to fix it is to get it wet sanded but i forgot what grit sand papers you're to work with.
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Try here:
http://www.corvetteforum.net/c4/blue92/targa_top.shtml
It's a fairly common problem.
[Modified by Blue 92, 6:48 PM 4/7/2002]
Re: glass roof panel peeling on a 96' (Blue 92)
It's a common problem. Once it starts you have to strip it the rest of the way or get the whole thing repainted with clearcoat.
It's worst, we've found out, on cars that are exposed to a lot of freeze/thaw cycles. Garaged cars that are left in cold parking lots during the day, or cars that stay outside all the time in climates where the temp does a lot of freeze/thaw cycles.
