Z51 and Z52 difference
Old 02-01-2011, 02:15 PM
Whitecloud
Whitecloud's Avatar
Default Z51 and Z52 difference
What is the difference between Z51 and Z52. Thanks in advance.
Old 02-01-2011, 02:52 PM
CRUZN C4
CRUZN C4's Avatar
2022 C4 of the Year Finalist - Unmodified
The Z52 had the Z51 equipment except the springs were the base ones and could be ordered with either transmissions. The Z51 starting in 87 was restricted to the manual transmissions.
Old 02-01-2011, 02:59 PM
c4cruiser
c4cruiser's Avatar
The Z52 didn't get the PS cooler and the shocks were the Bilstein Sport shocks. Z51 had stiffer Bilstein shocks. Base suspension car got an AC Delco shock.
The Z51 also got heavy duty offset lower control arm bushings. The Z52 rear sway bar was slightly smaller in diameter. But both Z51 and Z52 got the same size front bar.
Z52 was available on the convertible but Z51 was coupe only. Z51 and Z52 came with 16x9.5" wheels all around while the base car had 16.x8.5" wheels up front.
Old 02-01-2011, 08:00 PM
Whitecloud
Whitecloud's Avatar
Thank you for the info. Mine is an 88 I should have said that in my post. I am sure all is the same for the 88 except for tire size? Thanks again.
Old 02-02-2011, 06:52 AM
856SPEED
856SPEED's Avatar
the 84-86 cars have Z51 options as well.........I have an 85 Z51 optioned car
To Z51 and Z52 difference
Quick Reply: Z51 and Z52 difference
