91 fuel pump relay location?
Old 04-15-2011, 01:52 PM
imdaking06
imdaking06's Avatar
Default 91 fuel pump relay location?
can anyone tell me where the fuel pump relay is located on my 91 vette
Old 04-15-2011, 02:18 PM
Joe B.
Joe B.'s Avatar
"Inside the passenger compartment, under the dash." FSM
That would be in the vicinity of under the glovebox IIRC.
Old 09-13-2011, 03:31 PM
Expsd
Expsd's Avatar
Old 04-03-2012, 06:54 PM
Handi
Handi's Avatar
Default location?
This is what my fsm says also. However when I remove the carpeted panel there are no relays in this configuration. I found a box full of 5 relays unmarked. Is this the correct relays? They are also smaller than the relay I bought to replace. Please Help?
Old 04-03-2012, 07:39 PM
RetiredSFC 97
RetiredSFC 97's Avatar
St. Jude Donor '09-'10, '14
That would be them
What do you mean smaller? They are a square looking box thingy just like in the picture. Maybe they gave you the wrong one. Also IIRC those relays are interchangable.
Old 04-03-2012, 07:59 PM
Handi
Handi's Avatar
as I said they are smaller. (1 inch square) The one I bought is about 1 1/4" square. And they are not in a line like the fsm shows. They are in 2 rows. 3x3. So which is the fuel pump relay?
Old 04-04-2012, 07:56 PM
rodj
rodj's Avatar
If they are not setup as the FSM shows (obviously someone has been there before you) only thing to do is install a relay in each of the vacant positions until you find the correct one.
In any case why would you not want all those items working?
Old 04-04-2012, 09:27 PM
meganzhang
meganzhang's Avatar
fuel pump relay is on the right the other relay is ac compressor relay.
Old 11-22-2012, 11:33 AM
blackbob
blackbob's Avatar
Not to bring back a thread from the dead,but,I rather do this than make a new one ( proof that I searched the topic ). When I search this questions I get two answers,one says in the engine bay to the left of the brake boost. The other is inside the car under the dash on the driver side and now I'm reading passanger side. Is there a difference from model to model ?
Jbarr91 (07-03-2023)
To 91 fuel pump relay location?
Quick Reply: 91 fuel pump relay location?
