I know this is an older thread but pictures are fun so here's mine:......
My '96 had them when I bought it. These were cheap aftermarket ones that are no longer on the car, but it shows how they look. I like the stock painted ones or the '04 polished ones better.
I can't believe that doesn't rub. Please tell me that doesn't rub. I need to hear that doesn't rub.....
They fit front and rear with out rubbing... before I put my vansteel/QA1 coilovers on the front, which required the front sway bar to be relocated forward which also moves it slightly closer to the wheel, which made it slightly rub at full lock so I added 15mm hub centric spacers on all 4 corners (cost about $50), that solved the problem and they don't rub now at all.
They were pretty tight though before the coilovers but they did fit on my car without rubbing (no spacers).
Here are my stock C5 Gunmetal Z06 wheels on my car. By far my favorite wheels, 17's in the front and 18's in the back.
What year is your car? I need to get the right adapters for my 87. it had been facelifted to a 95 look, and had ~3/4" spacers on it for the Sawblades, but they used regular lug nuts that stick out way to far and the Z06 wheels also do not have near the recess for that as the saw blades... so, bummer for me, I will not be installing my newly acquired Z06 wheels quite yet.
