Camber Brace
Camber Brace
Has anyone with a C4 installed a camber brace? What was the result?
Here's their website: http://www.r-dracing.com/Camber-brace.htm
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
I have one on my 86.
There IS a felt difference in the twistys.
Its a bitch to install and is usually in the way when ever your working on the front of the engine.
Handling improvement... I'll give it a 7 out 10
Have one on order. Will let you know the difference.
On my 94 it is SCARY to remove my top and drive these curvy
and rough WV roads.
I have experienced a lot of bump steer. It actually made me think
the steering wheel was going to shake out of my hands.
and rough WV roads.
I was very happy with the way the steering wheel stabilized. The whole car felt more solid. Here is what I encountered when I installed it in July of '08. This was on my '91. Very tight fit, 1 bolt barely long enough because of the shims, 1/4" clearance at serp. belt by A.C. comp., move P.S. res. inboard 1/2", raise A/C drier 1/2", modify upper rad. hose bracket, it added 11# of weight. "But the improvement made it worthwhile."
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
The installation is complicated but, if you stretch the AC line all the way it will make it a piece of cake.
I had to remove the ones off my 96 to fix the oil leak and I grabbed a prybar and pushed out the AC line all the way out. It went in like the way it goes in to a date in the Philippines.
Yes, it will tighten your front end. I have it installed on each Vette.
You may want to read this thread from the C4 Tech section. Personally I do not recommend buying the Targa Truss from R-D Racing.
The Camber Brace may help with bump steer as the brace provides a solid connection between the front upper control arms. You may want to experiment with alignment to see if that can help too.
When I pull the roof, its time to slow down.......
I have the camber brace and cross-bar. Love the way my car drives and handles! Felt like a whole new car after installing both. But like said above, does very little with the top off.
iv considered the camber brace but whats holding me back is wondering how much difficulty it adds to working on the engine. i removed my whole a/c system to clear up space when im working under there, but i also added an electric water pump which would make it tighter up there
Now I have no a/c no smog/ no idler pulley, etc and I have tons or room for it, and I have full tilt adjustment that the bar allows for, and the reservoir is no where near it anymore.
The only thing I ever had to loosen it for to work on was changing pulleys.
haha ya well this years work is all going into suspension and brakes, that way next year i can start setting up for my ls1 swap. i forget, but i believe the ls1 sits back and inch or so from where the lt1 does so that would probablly add extra room with a camber brace. haha its being considered. i still need to get the sway bars and box in my x brace!
I have it, and it helps sturdy the car. It is not hard at all to put in, the only thing bothering mine was my frisbee which I removed anyway, and my power steering reservoir.
I have one in my 93 convertible, the brace tightens up the front end. When I installed it even with a shim it pulled in the tops of the control arms a bit. It makes sense to get an alignment afterwards.
If you don't have the A/C system any longer, it'll take about two minutes to get it out of your way to work on the car. Even with the A/C, I can pull it off to work on the front of the engine in under 10 minutes...most of which is getting it around the A/C hoses. They make a version for an electric WP. Doesn't look quite as robust to me, but probably still does the job well.
I liked it but can't use it now that I havr a supercharger.
Im prob going to try and sell it soon. If interested drop me a pm about it.
Thanks for the response, my car is a convertible and anything that provides stiffness to the structure is a welcome addition.
Here are some additional threads and info about this topic, also a Gordon Killebrew design C4 frame stiffener:
http://forums.corvetteforum.com/c4-t...orth-it-2.html
http://www.corvette-guru.com/modules...=12244&forum=1
