Good reason to replace rear control arm bushings
I will let you know what I eventually find out. So far 4 shops, including two corvette shops, have looked at it and can't figure it out. I'll show them 92ragtop's idea and see if that is it. Right now it does not seem to be getting worse and everyone has told me that whatever it is it does not seem to be a safety issue. I probably will not spend much money trying to figure it out unless it gets worse. I have no vibrations or noise at all, just the click, but I hate having something wrong with the car after I have spent so much money on the new engine.
Good news. I had a shop here in the Phoenix area install new teflon rear axle washers on both sides of my car today, the clicking noise is gone. When they started the work they discovered that the washers were missing on both sides. Apparently whoever replaced the U-Joints on both sides of the car last never installed the teflon washers at all. The washers are only about $10 each and the labor was only about $100. There is a great thread talking about this problem in the tech section. Do a search for "teflon rear axle washers" and look for the thread entitled "its the washers". Hope this solves your problem as well.
Received 5,010 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
its probably not any one big thing; on our aging cars, a lot of little things add up
OP, glad yours turned out to be something easily located and cheaply fixed!
I have a '92 with an automatic. Each time I put it in gear or put a little pressure on the rear end there is a click from the left rear. Once I'm rolling down the road there is no noise at all, just one click when pressure is first applied to the rear end. I've had all the u-joints checked out and everything looks fine. One mechanic thinks I need to replace the bushings in the rear. Did you have those symtoms on your car?
Thats about a $5 repair. $5 for the anti-seize.
Its surface 'rust' on the splined stub shaft on your left rear half shaft.
Remove wheel and hub, wire brush the splined stub shaft, and then coat both surfaces (hub and stub shaft) with anti-seize. Probably a good idea to do the other (right side) as well.
If you mentioned this 8 years ago on this site, you would get about 10 responses telling you the same.
This was the issue with mine, did this and no problem.
Could you imagine how bad you'd get raped if you took it to the dealer with that complaint?
Finally Replaced Lower Control arm bushings
.... another reason to replace the bushings.
1st pic - The LS arm fresh off the car; 2nd pic - What was left of the bushing after cutting the overhang off; 3rd pic - pressing the old sleeve out with the bench vise; 4th pic - Ready to reinstall!!!
