1984 Cooling Fan Relay-Switch trouble
2nd Gear
Im lost for what to check next on my 84, fan quit working, so I tore relay apart and made contact manual, fan comes on. I tried a new relay, no fan at even 250f, so I wired in a toggle, went to mech, we tried to ground out the temp switch, no fan, we tried to run a wire from switch to blue-white wire on relay, ran car to temp. No fan, tried unplugging the Ac switch, no fan. right now im wired with a toggle from the blue-white at relay to battery ground.Im lost the next option is a ground wire from fan to temp switch and how wire to battery, when switch reaches temp it grounds and the fan should work bypassing the relay all together.
Anything im missing here? I dont mind the manual switch though it seems a little stock carish for a vette, when things should work. I just got done total rebuild of the engine this is really driving my nuts. Also fuel guage, I ran out of fuel at 1/4 tank twice. Anyone have any problems with the guage?
Hey Cor-vetter.....I have a similar problem with my fuel guage.....only it's not quite that bad at running out at 1/4 tank. When mine still shows like 2 lines, you're empty....Let it happen to me once since owning my '84. Haven't worried about troubleshooting it. As far as the other problem, your fan not operating, happened to me, too. Garage diagnosed as a bad cooling fan relay and they replaced a cooling fan thermal switch. Fan turns on at 228.
Obviously.
Switch goes to ground when A/c operating same as the fan temp switch does
2nd Gear
Have you tested the switch to see if it actually works?
Which will most likely burn up the wiring due to the heavy current load fan draws ( which is why the relay is there in the 1st place)
Obviously.
Obviously.
ok..my 1984 has the same heating problem..fan will not come on. replaced thermostat,relay and sensor. still will not come on. exactly what will it take to get it to work with out jerry rigging it...does the ac preasure switch have any thing to do with it?
Are you sure you have the right relay?? By the drawing from vetteoz there is no blue white wire on the relay ( drawing is 8A-149 from the electrical manual).. If you pull the connector off the temp. switch and ground it with the car in run the relay should operate and fan should work.. If the relay doesn't operate check the 3 amp fan fuse. If the relay operates but the fan doesn't check the fusible link. Both the temp switch and the ac pressure switch provide a ground to operate the relay..
