Napa distributor caps
Old 08-23-2011, 01:46 PM
SQUIRMIN VERMIN 84
SQUIRMIN VERMIN 84's Avatar
Location: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
Default Napa distributor caps
I usually buy my distributor caps from Napa( brass terminals-Echlin). I got my latest home and after transferring the coil into it's heated crematory in the top of the cap, I noticed the 4 plunger-twist screws to fasten the cap to the dist body were missing! All the cap had were 4 flat tabs with open screw holes and a 4-pak of screws to install.
I told Napa they gave me the wrong cap. They pulled it up and there it was for an 84 vette- pictured a flat tab screw mounting! Part # Echlin RR214. I had them check other manufacturers listed and they all showed the correct plunger-screw caps. I showed them my old Echlin cap which I purchased at that store and they agreed, the new one didn't look right. All their Echlin caps in stock had the flat screw tab mounting.(I had them check). I think their database is hosed, but they were insistent-that's what we show for your car! Got a refund but WTH?
Any one else have this problem lately with Napa?
Old 08-23-2011, 03:44 PM
84cfi
84cfi's Avatar
Take it back and go to auto zone.
"If you want it and need it they got it at auto zone"
Old 08-23-2011, 05:19 PM
c4cruiser
c4cruiser's Avatar
I had a similar problem when I ordered a MSD cap for my 87 from Summit Racing. My distributor uses screws for the cap and not the spring-loaded clamps. The MSD website showed a listing for the early C4's but it was the same part number for all.
Accel caps show only the spring-loaded HEI caps for C4's.
I sent it back and got a Taylor cap. The Taylor website shows different part numbers for the two different caps for the early C4's.
Most AutoZone stuff is cheap bakelite and aluminum terminals and while they carry Accel stuff, there is no specific C4 listing for screw-down caps.
Old 08-23-2011, 05:42 PM
SQUIRMIN VERMIN 84
Yeah, Auto Zone is on my bottom-of-the-barrel list...
Never heard of Taylor. Manufacturer or retail store?
Old 08-23-2011, 05:58 PM
ps374
ps374's Avatar
Yes I had a simular problem with one of their caps. I went to auto Zone and they had everything I needed. The auto zone quality was also much better.The only problem with auto zone is not everyone who works there knows cars. You have to get the right sales rep.I also found them cheaper then most other stores.
Old 08-23-2011, 06:25 PM
Bob M
Bob M's Avatar
I had to take my NAPA cap back and went to AZ for the right one. But likeps374 said, I had to get the right guy to find it for me. I HATE the aluminum caps!
Old 08-23-2011, 08:03 PM
blackbear bob
blackbear bob's Avatar
RR171 is the correct cap for your aplication
Old 08-23-2011, 10:37 PM
SQUIRMIN VERMIN 84
Thanks Bob, I'll check that out with them tomorrow!
I always tear off the box end flap of all my parts I buy and keep them in a separate envelope for each
car. That gives me the brand and part # when I restock. Damned if I didn't find one in there for the cap!
Old 08-23-2011, 10:42 PM
84wannabezo6
84wannabezo6's Avatar
My 84 uses the four screws not the L shaped springy things
Old 08-23-2011, 10:49 PM
SQUIRMIN VERMIN 84
What's the manufacture date on your car? Sticker on rear end of driver's door. Mine is Sept '83. Maybe it was a mid year change?
Old 08-23-2011, 11:03 PM
HlhnEast
HlhnEast's Avatar
I was gonna suggest this, I also write the number down in my Service manual. This helps even more when you get away from stock.
I also believe in Echlin and buy from NAPA but I went with Taylor (a red one) cap and rotor this last time. Great quality as always. I like their wires as well.
Good luck with it.
Old 08-23-2011, 11:15 PM
SQUIRMIN VERMIN 84
Good luck with it.
Never heard of Taylor. Is it a manufacturer or a retail store?
Old 08-23-2011, 11:23 PM
HlhnEast
HlhnEast's Avatar
They are a well known ignition products manufacturer. Go to Summit and just put Taylor in the search and see how much is out there. Cool thing is they make plug wires in almost any color under the rainbow. Good for custom engine compartments
Old 08-24-2011, 08:40 AM
h.d.fire
Support Corvetteforum!
h.d.fire's Avatar
I had the same thing happen when I bought one from Summit for my 89'.
I didn't install it right away, the return period lapsed and I got stuck taking a loss on it by selling it on craigslist. Purchased a good Echlin (copper contacts) cap at Napa.
To Napa distributor caps
Quick Reply: Napa distributor caps
