Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
- Corvette Jack Up Your Vette How to
Step by step instructions for do-it-yourselfers.
Jacking up a C4..
Jacking up a C4..
I have another question on jacking up our C4's. I have been using the jacking points to raise my car. I was changing the oil the other day and saw the cross member. Why can't this be used to jack up the front of the car with a low profile jack? Is this an area that would be strong enough to lift the car?
I often use the front crossmember to jack the car. I use a small cheapie Harbor Freight jack under the jacking points to get it high enough to center the big floor jack under the crossmember, and then up it goes....the whole front end at one time. You can then position your jack stands under the front factory jack points.
Then.....once the front is up, you can raise the rear by the shock mounts and put the car on 4 stands easily.
1 Post
Watch some of your magazines they have a 20% off coupon for HARBOR FREIGHT and it can save you more $$$$. A lot of the time they will let you use it on sale items also.
Good SHOPPING
wro87
Good SHOPPING
wro87
I just use their $20 trolley jack to get the nose up a bit, then use my big Craftsman floor jack to finish things off. The next time I see a coupon for their aluminum racing jack for $59, it's following me home though.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
This is something you guys can do. If you have a low profile jack and your Vette has
not been lower you can rise the Vette using the lower cross member.
If your Vette has been lowered the spoiler will not allow a low profile jack to go
under the Vette.
You can go to Home Depot, buy a plank of lumber and build a small ramp like this
one (photo below). It will rise your Vette high enough for any jack to fit and get
it on jack stands.
under the Vette.
it on jack stands.
2017 C4 of Year
Now, lets say you can not afford to buy planks there is another way I used to do before I bought mine. For this you need another jack, at least the cheap 2 1/2 tons.
On one side you lift enough for the jack to fit and raise at the cross member.
You place your 2nd jack here, raise it until the jack fits underneath. Don't worry, it will balance itself out as long you place the jack dead center on the cross member.
This works for me. Rhino ramps and some 2 x 6 planks. I drive up onto them while looking at an old mirror that I have propped up so I can see where the left front wheel is. Then unlatch the ramp and pull it away. I then use a Jack a Vette on the rear pumpkin and set jack stands under the rear. Allows plenty of room to lay on a creeper and work on the car's underbelly.
I will probably sell this lash up some day when I can afford to buy a real lift.
