which rear end does my 1994 have?
Old 12-07-2011, 06:45 PM
Cavi
Cavi's Avatar
Default which rear end does my 1994 have?
where do I find out what rear end and ratio my 1994 base coupe with six speed has?
Old 12-07-2011, 06:48 PM
VetteMed
VetteMed's Avatar
Six speeds had the 3.45 rear axle ratio. You can confirm this by looking at the stamped numbers on the bottom of the center chunk of the differential housing. they are tiny, and may be dirty, but they should be there.
Also, you can check the center console lid for the RPO Codes, Rear axle ratios usually are either GU_ or GT_. There's lookup tools available all over the web to find the right code.
Old 12-07-2011, 06:52 PM
QCVette
QCVette's Avatar
It should be a 3.45 ratio that is code GM3 on your SPID label.
GM1 = 2.59
GM3 = 3.45
GT7 = 3.33
G44 = 3.07
These and other codes are listed several places, but the one below is a pretty good site.
http://www.corvetteactioncenter.com/...94/94prod.html
Old 12-07-2011, 07:03 PM
Cavi
Cavi's Avatar
thanks, yes mine has GM3!!! It could even go lower like a 3:3 and I would be happy. I take it all the 1994 had Dana 44?
Old 12-07-2011, 07:16 PM
VetteMed
VetteMed's Avatar
All 6-speed cars had the Dana 44.
Old 12-07-2011, 08:14 PM
James93LT1
James93LT1's Avatar
Why would you want to go Higher?
To which rear end does my 1994 have?
Quick Reply: which rear end does my 1994 have?
