How do I know if I have heavy duty suspension?
I'm looking to replace all my rotors and pads and the different brake kits have my 91 C4 broken into 2 different prices. With heavy duty suspension and without. I looked at the orginal window sticker and looked at my VIN# on Vette Facts, but I cant tell if my car has the "HD Suspension" Its not a big price difference in the rotors and pads, but I want the correct product.
Any thoughts.....? THANKS!
Wow I never knew what all those codes on the inside of the center console were for. Thanks guys, I have the FE1 standard suspension.
I love this forum, thanks for your help
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
If you have J55 the only difference is the rotor & caliper on the front, they all use the same pads.
http://www.wedophones.com/Manuals/Chevrolet/Corvette/1984-1996%20C4%20Corvette%20Suspension%20Tuni ng%20Chart.pdf
Z52 I believe just added shocks, wheels, engine oil cooler, I believe the 2 turn rack/pinion and HD radiator.
I don't believe Z52 got the J55 (13" brakes), so you would need calipers, rotors and caliper brackets to the knuckle to put larger brakes on your '88 in the front. Measure a rotor and if it's closer to 12" it's base brakes and if 13" then it's J55 which might have been added along the way.
Pro Mechanic
Psssst; This thread is almost 3 years old.
Psssst: but the response I and others have done are in response to this "recent" post to the thread which is #12. This should take you there:
https://www.corvetteforum.com/forums...post1587845879
Pro Mechanic
Ah yes....indeed. I failed to read the whole thing, thoroughly. Excuse me while I go eat my crow filled, humble pie.
