So how many of you guys are doing/done LSX swaps?
I have noticed a few poeple speaking about their on going or swaps that are done. If you are doing a swap or have done one please share pictures and specs. I'm not asking you to do a write up just share pictures and experience please.
Well...you know about mine...but since you ask...
Having an EROD LS3 & 4L70e swapped into an '87 as we speak.
Just a couple of pics, link to build thread at end:
Anxiously waiting for the builder to fill this hole:
http://forums.corvetteforum.com/c4-g...-erod-ls3.html
Man that does look awesome under a clamshell hood!
I have about 17,000 miles on my LS3 Hot Cam (GMPP LS376/480 Hot Cam). There is a thread in the Perf and Tech C4 section entitle "LT1 conversion to LS3 Hot Cam", or you can google "C4orce2" and look for the photobucket. The thread has some pics and discussion about the build. The photobucket has an album with around 30 pics of the build.
Here's the thread mentioned above:
http://forums.corvetteforum.com/c4-t...3-hot-cam.html
This is great
I forgot to post mine
!Mod It if you Got IT!
Replacing the L98 with an LSX ... My swap
http://forums.corvetteforum.com/c4-t...x-my-swap.html
This is the project that first fueled my swap.
http://www.vetteweb.com/tech/vemp_11..._up/index.html
This thread is also very helpful. Its full of great info.
http://forums.corvetteforum.com/c4-t...ith-4l60e.html
Here are more
http://www.vettaid.com/LSxPackagesKits.aspx
http://www.carcraft.com/techarticles...NTERSTITIAL_15
http://tech.corvettecentral.com/2010...-c4-corvettes/
http://www.vetteworksonline.com/c4_c...conversion.htm
http://www.digitalcorvettes.com/foru...ad.php?t=62126
http://forums.corvetteforum.com/c4-t...vail-soon.html
http://forums.corvetteforum.com/c4-z...sx-motors.html
http://forums.corvetteforum.com/c4-t...-early-c4.html
http://www.ls1tech.com/forums/conver...-corvette.html
http://www.ls1tech.com/forums/conver...ject-pics.html
http://www.ls1tech.com/forums/conver...wap-build.html
http://www.corvetteactioncenter.com/...wap-build.html
http://www.smokinvette.com/corvettef...ad.php?t=33667
LS bolt size chart
http://www.gmperformanceparts.com/_r...D_19202977.pdf
Wiring links
Pin outs for LS swaps (Thanks 85MikeTPI)
http://ls1tech.com/forums/conversion...swap-faqs.html
C4 Vette wiring diagrams 85-91
https://wiki.bentleypublishers.com/d...agrams19901991
LS1 pcm wiring diagrams and more
http://www.ls2.com/boggs/torques/enginetorques.htm
Posted by LS1MCSS .. a very valuable resource
http://www.ls1tech.com/forums/conver...chematics.html
TPI swap wiring diagrams on line.
http://www.chevythunder.com/fuel%20i...%20pinouts.htm
Here are more
LS bolt size chart
Wiring links
jb35007 (10-28-2015)
I'm doing a VVT L99 & T56 into a '92. I'm putting in scat rods and inv dome Mahle -12cc pistons, eyeing a magnuson in the future. Some things I've found
The speed hound sbc-ls conv mounts seem to give me a slight setback in the LT1 frame mounts, it doesn't look like a major problem and the VVT likes it since it sticks out 1.5" from vette FEAD.
The C6 air intake works great in the C4 and K&N makes a hiflo filter for it. The speed density TPI camaro intake bellows flipped around mate to the intake and TB. The integrated MAF card slot was the coup-de-GRAS
Using the C6 FEAD spaced 1.5" setup with a 2010 camaro LS3 water pump to clear the VVT. The A/C will wait until the cars running. Getting a 2010 camaro starter also and wiring it in. Inexpensive and the revised 2-long bolt design.
HPtuners on a E38 ECM for the VVT support will handle the engine and I'm adapting the '07 escalade harness from the L92 engine to wire everything.
Still collecting parts and waiting on the back ordered pistons to finish the long block.
Getting the '07 monte DBW pedal, have an LS3 takeoff intake, LS3 vette oil pan, TSP VVT2 cam, Melrose swap headers, and loads more..
My build link over on ls1tech:
http://ls1tech.com/forums/conversion...-t56-swap.html
I purchased an ls6 with 31,000 miles and transported it into an 1985 manual car using an level 3 performabuilt 4l60e. Mine does not have any "creature comforts" though. Just a driver. Might play around at autocross or a strip for fun at some point.
http://forums.corvetteforum.com/c4-t...-ls6-swap.html
http://ls1tech.com/forums/parts-clas...ls-blocks.html
Wow, where do I start...
Ch@0s: Great thread & love that link list.
Agent13: Looks great. I'll have to find some of those Corvette covers, the EROD doesn't come with anything equivalent.
85MikeTPI: Flipping the fuel rails should work---saw that in an old 2003 vintage swap thread---& we're planning on doing that on mine. I wonder if it will interfere with the nifty Corvette covers?
Any of you looking for cruise control? I just bought a drive by wire compatible cruise module from http://spankysrodshop.net/
Maybe we need a hybrids/engine swap section, eh?
Unfortunately that is an older picture. I need to take an updated picture with the A/C hoses installed.
Great thread, will be studying those links. My LT1 is out, shopping for the LS to put in. Who has a lead on one for me?
I'll be keeping the ZF6 trans.
wow !! c4+ls3 ? I don't need anything else
I was planning for ls swap , but since my engine is making good power and give good results racing new cars I forgot about the swap, until the lt1 dies. Then there will be a future plan. Hopefully something like this pic
how much did you pay for the whole project ?
